<back   Jemsite > Jemsite.com Start Here > Archived Topics and Common Questions - GO HERE FIRST
Archived Topics and Common Questions - GO HERE FIRST Common topics/questions are archived here. You can reply but not start new threads here. NEW MEMBERS PLEASE GO HERE BEFORE POSTING a question after searching.
Old 12-25-2000, 12:45 PM
bduersch  is offline
Posts: 1,357  -  iTrader: (1)
Blue velvet vs. Jem single coils - Differences? Anyone? Anyo
Merry Christmas, Jemsters!
Having received X-mas funds to upgrade my guitars (a Christmas dream come true), I'm working on upgrading my RG-1200 to evolutions w/ a blue velvet. Has anybody else done this? How does the blue velvet compare to the Jem single coil (in terms of perceived output level and/or overall tone)?
Any comparisons to the VWH, BSB, or DBK tone would be helpful, since all of those Jems have graced my presence at one point in time.
Thanks much!
--Brent
Old 12-26-2000, 09:53 AM
Vaibanez  is offline
Posts: 813  -  iTrader: (5)
The Jem single coil is very simaler to DiMarzios HS-2. Below are the specs strait from the 2000 cataloge.
HS-2(Jem Single) :
Output * * * * * - 90mlv
Treble * * * * ** - 7.5
MidRange * * * *- 5.5
Bass * * * * * * *- 5.0
DC Resistance - 14.97k
Blue Velvet Bridge :
Output * * * * * - 153mlv
Treble * * * * * *- 8.5
MidRange * * * *- 5.0
Bass * * * * * * *- 4.0
DC Resistance - 7.05k
Blue Velvet Neck :
Output * * * * * - 120mlv
Treble * * * * * *- 9.0
MidRange * * * *- 4.5
Bass * * * * * * *- 3.5
DC Resistance - 6.08k
Old 12-26-2000, 10:42 AM
Kevan  is offline
deleted username
Posts: 1,429  -  iTrader: (0)
The HS-2 is ***NOT*** the "JEM Single". *
(Once again) here's how the single coils in the JEM guitars goes:
•If you have PAF-Pros, the single coil is custom-made to match the PAF Pro's.
•If you have Evolutions, the single coil is custom-made to match the Evolutions.
•If you have Breeds, the single coil is custom-made to match the Breeds.
Each matched s/c is different than the other. *They are custom built for Ibanez (for the JEM guitars only) and are NOT available to the general public.
Example: the s/c from a DBK won't match up very well when dropping it in an FP or *VWH. *
And vice-versa: the s/c from a VWH won't match the h/b's in an LNG or a DBK.
That being said, the HS-2 is a close match to the s/c's found in PAF-Pro-equipped JEM's.
(Information courtesy of the #2 man at DiMarzio)
Old 12-26-2000, 02:16 PM
MrGreenGenes  is offline
Posts: 12  -  iTrader: (0)
The PAF Pro version sc pu might be closer to the DiMarzio FS-1, I recall seeing one RB Jem with one. *
Old 01-13-2001, 01:22 PM
bduersch  is offline
Having FINALLY complete this project, here's my $0.02.
Although I love the VWH, I've always found the middle pickup position pretty useless in terms of output. Good tone, but not enough output.
The evolutions combined with the Blue Velvet is awesome. All of a sudden, all 5 pickup combinations are relatively consistent in output level. The tone is great. I'm considering (although I really don't enjoy rewiring guitars) putting a Blue Velvet into the VWH.
--Brent
Old 01-28-2001, 12:22 PM
mecca777  is offline
Posts: 168  -  iTrader: (0)
What about the single-coil in Japanese PGMs? I was led to believe that's a JEM single as well. If that's the case, I assume it's the "PAF Pro" one, but I have no JEM to compare it against.
Old 01-28-2001, 02:36 PM
tomizm  is offline
Posts: 417  -  iTrader: (1)
So, if I wanted to put Breeds in my Jem Floral, it wouldn't work? *or it just wouldn't react with the 2 and 4 pup positions like I think it will?
What if I tried it anyway?
Old 01-28-2001, 03:45 PM
jemsite  is offline
Administrator
Posts: 9,259  -  iTrader: (5)
Images: 11
The Breed neck and bridge would work GREAT in a Floral. They worked great in my 7PBK. Forget the specs and use your ears as a guide. I don't have output measurement on the JEM single coil from every year/model but they are all about the same to my ear and much lower output than their respective matching pickups. Maybe DiMarzio can supply this. Until then they are sort of confusing the issue with incomplete and perhaps incorrect information... glen
Old 07-26-2001, 03:22 PM
tomizm  is offline
Breeds in your Floral????? *I was thinking the exact same thing. *I never figured I could just leave the single in there though. *Good idea! *When I come across some cash, I just might do that.
Will Dimarzio's current shade of pink match the pink I have in the floral? (all considerations for fading put aside)
blue velvet bridge, paf pro, pickup combination
