<back   Jemsite > Jemsite.com Start Here > Archived Topics and Common Questions - GO HERE FIRST
Archived Topics and Common Questions - GO HERE FIRST Common topics/questions are archived here. You can reply but not start new threads here. NEW MEMBERS PLEASE GO HERE BEFORE POSTING a question after searching.
Old 02-20-2012, 07:36 PM
A.Squier  is offline
Posts: 4  -  iTrader: (0)
edgeiii
Can someone tell me if the edgeiii trem on my 07' rg4ex1 has the same pivot bolt dimensios as well as body milling shape as floyd rose trems? Or will a floyd rose pretty much drop in place. Not too thrilled with edgeiii at this point. Only had it for a month so far.
Old 11-17-2012, 08:47 PM
tony b  is offline
Posts: 2  -  iTrader: (0)
Re: edgeiii
The posts are 74 mm apart on the edge iii and the same on the Floyd. They are the same , where you may have trouble is the routing of the body and the threads on the post screws. If they are fine thread on the Edge 3 you have then you should be okay . If not you will need to replace the bushings that hold the post screws. They come with the tremolo. I just put in a Floyd Rose Special and got rid of the Edge 3 . Mine dropped in with no probs. Feels so much more stable and solid.
FS/FT Ibanez JS100 (edgeIII version) Sportrider24 Classified Ads: Guitars and Gear 1 02-10-2012 10:25 PM
totally screwed over by my edgeIII sylphin Tech: Setup, Repairs and Mods 7 10-04-2009 11:42 AM
