<back   Jemsite > Jemsite.com Start Here > Archived Topics and Common Questions - GO HERE FIRST
Archived Topics and Common Questions - GO HERE FIRST Common topics/questions are archived here. You can reply but not start new threads here. NEW MEMBERS PLEASE GO HERE BEFORE POSTING a question after searching.
Old 04-03-2001, 08:10 PM
dacmo  is offline
Posts: 163  -  iTrader: (0)
Is the Lo-Pro a direct replacement for the Edge cavity wise?
This should a simple question...
Can I just replace the Edge trems on older Jems (Like FPs) for a Lo-Pro without any routing?
Thanks.
Old 04-03-2001, 08:48 PM
tomizm  is offline
Posts: 417  -  iTrader: (1)
My JemFP came with an Edge in it, and I slapped a Lo Pro in there with no issues.
Old 04-03-2001, 08:56 PM
dacmo  is offline
Cool... Thanks
Old 04-03-2001, 09:17 PM
kirk  is offline
Posts: 1,554  -  iTrader: (5)
The only difference is the length of the route. *It's longer on Edge equipped guitars.
But - they will direct swap, just like tomizm said!
Old 04-04-2001, 02:04 AM
Project Guitar  is offline
Posts: 979  -  iTrader: (0)
One other thing you might want to look out for is the difference in length of the ( I'm not sure of the tech name) Transfer bar - the wide flat bar that sets between the top of the trem and the springs....
See pick below of one taken off another Edge Lo-Pro against the Edge Lo-Pro I have been saving for a project and there are considerable differences in length...
Old 04-04-2001, 02:11 AM
jemsite  is offline
Administrator
Posts: 9,260  -  iTrader: (5)
Images: 11
the longer base is from a non-recessed Edge. Seen on '86 and earlier Ibanez'. No LoPros should come that way... glen
Old 04-04-2001, 02:35 AM
Hummmmmm...
Somebody probably performed surgery on it before I got then since the top is a standard Lo Pro Edge....
Old 04-04-2001, 02:37 AM
jemsite  is offline
Administrator
Images: 11
the longer base will typically protrude beyond the tremolo cover in a standard RG/S body... glen
Old 12-06-2002, 06:35 PM
hyesac  is offline
Posts: 59  -  iTrader: (0)
yes direct swap
Old 02-02-2004, 02:32 PM
Cassius  is offline
Posts: 1  -  iTrader: (0)
Anyone know how much work this mod will take? I wrecked my edge trem on my RG570 so im really considering a Lo Pro ( there is no difference between Lo Pro and Lo Pro Edge, right? ).
It it just a case of taking off the springs, assembling the trem then putting it on the studs already there?
Thanks for any help guys
Old 02-02-2004, 02:34 PM
jemsite  is offline
Administrator
Images: 11
the edge and lopro edge are 100% interchangeable ...glen
Old 02-02-2004, 02:35 PM
Rich  is offline
Pull the trem with the strings on
http://www.ibanezrules.com/tech/setup/remove.htm
Pull the strings off the edge and stick them in the "whatever". Reinstall.
edge trem, edge trems, equipped guitar, pro edge
