Jemsite.com Start Here
Archived Topics and Common Questions - GO HERE FIRST
locking nut tuning problem - string retaining bar all the wa
Common topics/questions are archived here. You can reply but not start new threads here.
NEW MEMBERS PLEASE GO HERE BEFORE POSTING
a question after searching.
02-15-2001, 11:27 AM
utopia
Posts: 13 - iTrader: (
On my JS1000, when i lock the nut, the e string pulls sharp.
This would be an obvious problem. But when i lowered
the
, i went as low as possible and
its still happening. what should i do next?
the nut already has a factory shim under it, and
its set at the perfect height for the strings on the neck,
but can i get a slanted shim to raise the back of
the nut to solve this problem?
or could this be something else?
thank,
mike
utopia
Find all posts by utopia
02-15-2001, 01:58 PM
jay ratkowski
Posts: 2,273 - iTrader: (
Reviews: 3
generally when you put that added force on the string (via tightening the
locking nut
) it will pull sharp. *At least, that's how it usually is for me. *That's why there are fine tuners. *
jay ratkowski
Visit jay ratkowski's homepage!
Find all posts by jay ratkowski
02-15-2001, 03:25 PM
utopia
Yeah, I can accept a little pull to sharp, but this
goes a quarter step sharp only on the low e.
the other 5 strings change hardly at all.
utopia
02-15-2001, 03:32 PM
Posts: 19,344 - iTrader: (
It's typical. All you have to do is leave it a 1/4 step flat before you lock down. Not rocket science!!
02-15-2001, 04:34 PM
jemsite
Administrator
Posts: 9,260 - iTrader: (
generally when you put that added force on the string (via tightening the locking nut) it will pull sharp. *At least, that's how it usually is for me. *That's why there are fine tuners.
I disagree. If you set the
retainer bar
properly, the string should NOT go sharp at all.
In fact, if you study the mechanics of the locking nut, you'll see with the clockwise tightening of the pressure pad, the torque could pull one string will slightly sharp, and the other string flat, since each pressure pad effects two strings. The low-E could pull sharp, while the A pushes flat. This only happens if the nut is worn/sloppy, pads worn, of if you overtighten slowly allowing the pressure pad to rotate. Investigate further... glen
jemsite
Find all posts by jemsite
02-15-2001, 04:46 PM
Coolstu
Posts: 175 - iTrader: (
There must be something wrong. After tuning the guitar, tightening the locking nut screws shouldn't really affect the tuning.
Coolstu
Find all posts by Coolstu
02-15-2001, 06:22 PM
utopia
Well I guess if Rich says it's typical, I'll have to live with it.
Never had the problem with my jem, though
utopia
02-15-2001, 09:34 PM
Vaibanez
Posts: 813 - iTrader: (
The locking pads have a rounded inner side. Make sure this is lined up with the rounded top of the nut. Also, make sure the nut is tight to the neck. You also may have the string retainer TOO low, which woud cause tuning problems.
J>
Vaibanez
Find all posts by Vaibanez
02-15-2001, 11:24 PM
Diferent nuts are set at diferent hrights, as Glen said just screwing down the retainer usually stops this, but some just don't have an answer. A couple of my JS's are like that and I really never think twice about it, I'm too busy futzing with everybody elses stuff. I just leave the low e a few cents short and it all works out
02-15-2001, 11:30 PM
jemsite
Administrator
*TRANSLATION *- i'm a slacker technician who doesn't mind using the fine tuners as a workaround
jemsite
02-16-2001, 12:35 AM
steve
Posts: 590 - iTrader: (
If I may say so... the likely situation is that the locking pad is a little 'loose' in the pad slot of the nut. And hence, as it's being locked down, there is that twisting action that's allowed by the extra room of the pad slot. That would pull the Low-E sharp, and that string will show that quite quickly in terms of how many cents it goes up. Does the A happen to drop a bit, to go along with that?
I assume that all
locking nuts
have this to some degree; my solution is simply to pre-pressure rotate the locking pad in the slot enough that it can't twist (or not much) as the screw pressure locks it down. This really minimizes how much the strings are pushed/pulled.
Another important factor to watch for; never overtighten those locking screws - that'll cause exaggeration in the tuning tweaks of the lock-down procedure.
steve
Visit steve's homepage!
Find all posts by steve
02-16-2001, 01:00 AM
OK, absolutely true when it comes to *my* guitars. I've got 6 I kept from last year I haven't even had time to clean and change the strings yet!!
02-16-2001, 02:07 AM
kirk
Posts: 1,554 - iTrader: (
I've the same problem with one of mine, but my problem is obvious, the nut is a POS, and the slots are so worn that even with the retainer buried in the headstock, the strings still do not rest in the proper place.
kirk
Find all posts by kirk
07-26-2001, 02:32 AM
jemsite
Administrator
jemsite
10-15-2001, 10:55 AM
shredmaster
Posts: 2,330 - iTrader: (
yeah, what rich said!
shredmaster
Visit shredmaster's homepage!
Find all posts by shredmaster
locking nut
locking nuts
retainer bar
retaining bar
why doesn't dave weiner use a locking nut?
what locking tuners fit agile 2000
mushroomhead tuning?
problem frequencies when mixing
use a .016 for the 2nd string?
10:36 AM
