<back   Jemsite > Jemsite.com Start Here > Archived Topics and Common Questions - GO HERE FIRST
Archived Topics and Common Questions - GO HERE FIRST Common topics/questions are archived here. You can reply but not start new threads here. NEW MEMBERS PLEASE GO HERE BEFORE POSTING a question after searching.
Old 02-20-2012, 06:58 AM
Jemini920  is offline
Posts: 27  -  iTrader: (0)
Question
Steve Vai Slide Holder (Question)!
Ok does anyone know what Steve Vai is using as his slide holder on the back of the headstock on his Jem (Evo III i think) I cant find anything besides a mic stand slide holder and a slide holder called the slide fly which isnt what steve uses... if anyone knows plz feel free to post and DONT say "velcro"last time i checked glass/metal slides dont stick to velcro
Old 02-20-2012, 07:19 AM
elcid  is offline
Posts: 9,012  -  iTrader: (12)
Re: Steve Vai Slide Holder (Question)!
http://lmgtfy.com/?q=steve+vai+slide+holder
Why wouldn't Velcro work? Sticky back Velcro with one piece stuck to the guitar and one piece to the slide. glass/metal doesn't have to stick to Velcro. Velcro will stick to Velcro.
Old 02-20-2012, 07:36 AM
well first steve has no velcro on his slide second if you put anything on a glass slide it will interfere with the strings and/or anything on the slide itself will damper tone resonance of slide.
Old 02-20-2012, 08:03 AM
elcid  is offline
no it wont, just dont use the side that has velcro on it on the strings.
Old 12-10-2012, 05:22 PM
vanx00  is offline
Posts: 5  -  iTrader: (0)
I found this on Ibanez.com forum:
"Siro Vai - Hi, this is Steve. In order to put the slide someplace while I play the melody, I put a little piece of velcro on the slide and then a piece on the back of the neck. Then when I need to loose the slide I slam it in place on the back of the neck. It's also very easy to retrieve it for the choruses. I love Velcro!"
Old 12-10-2012, 06:37 PM
dickicker  is offline
Posts: 116  -  iTrader: (0)
I heard of someone putting a magnet on the headstock. Idk if they glued it or what.
bad horsie, question, slide, slide holder, vai equipment
question about Steve Vai xsundae Players, Bands, People, Music & Tours 4 02-06-2010 01:03 PM
Slide guitar. tomkatzz Tech: Setup, Repairs and Mods 0 03-20-2007 03:03 PM
arm holder question trixdropd Tech: Setup, Repairs and Mods 4 03-19-2007 10:17 AM
Can you play slide like this?? Hmmmmm ibanezcollector Multimedia: Music, Pictures & Sounds 14 05-14-2006 07:14 AM
A bit of Swamp Slide Jim Soloway Multimedia: Music, Pictures & Sounds 0 09-07-2004 07:17 PM
