<back   Jemsite > Jemsite.com Start Here > Archived Topics and Common Questions - GO HERE FIRST
Archived Topics and Common Questions - GO HERE FIRST Common topics/questions are archived here. You can reply but not start new threads here. NEW MEMBERS PLEASE GO HERE BEFORE POSTING a question after searching.
Old 05-31-2001, 09:04 PM
davenit  is offline
Posts: 324  -  iTrader: (3)
To "F" space or not to "F" space... - What the "F"...
I just received a steves special from a friend of mine for a "red lace" project I am working on. It is not F spaced. I have done this in the past but just wanted opinions on putting a regular spaced PU in an RG body....
Thanks
Dave
Old 05-31-2001, 09:15 PM
Vaibanez  is offline
Posts: 813  -  iTrader: (5)
Being that it's a Steve's special, I'll assume it's going in the bridge position.
I had a Duncan in my 560 for a long time. It was not F spaced and I heard no noticable difference in sound.
Go for it....man!!!!
J>
Old 06-01-2001, 12:25 AM
jay ratkowski  is offline
Posts: 2,273  -  iTrader: (7)
Reviews: 3
If you direct-mount the pickup, you can usually balance it out really nicely using a non-F-Spaced pickup. *Good luck.
Old 06-01-2001, 10:49 AM
armadillo  is offline
Posts: 59  -  iTrader: (0)
I don't think it makes any difference...When I bought my S2020 the Ibanez QM bridge pup wasn't F-spaced...You could clearly see that the poles on the pup were not aligned with the strings...
When I changed that pickup, I bought a F-Spaced ToneZone and it aligns perfectly with the strings now..But I am sure it doesnt really change anything for the sound....
my 0.02$...
Old 06-01-2001, 11:07 AM
jemsite  is offline
Administrator
Posts: 9,259  -  iTrader: (5)
Images: 11
asthetics aside, i don't believe you can hear the difference between the F-spaced and std pickups... glen
Old 06-01-2001, 11:18 AM
bluenote  is offline
Posts: 133  -  iTrader: (0)
i agree here too....i never worry about f-spacing....magnetic fields dont just go striaght up....the field looks kinda like a 3 dimensional bell...i guess.....dont sweat it
Old 06-01-2001, 03:10 PM
ripl3y  is offline
Posts: 747  -  iTrader: (0)
yup,
linin' 'em up exact aint important at all unless you like things to look just perfick!
If you do then best to get an F spaced bridge and a standard neck (i.e. i find the standard neck lines up better than the F spaced neck)
Steve
Old 06-01-2001, 03:56 PM
J Todd Beachler  is offline
Posts: 248  -  iTrader: (0)
It's not a big deal. *Dimarzio doesn't even make F spaced 7 string pickups. *Anyone notice that?
Old 06-01-2001, 04:27 PM
frankfalbo  is offline
One disappointment to me was when everyone made F spaced versions of their already standard pickups, I could notice a difference in the tone that I didn't like. I don't mean regarding the outside strings, I simply mean that when adding width to the coil you get more resistance for the same number of turns, or a smaller coil size for the same amount of resistance. *Seymore Duncan tried saying that his trem spaced pickups had a little more beef to compensate for the thinness of floyd type trems. But I think that was clearly an afterthought of putting the same number of turns on the wider bobbin. With the newer Dimarzio's, a lot of them were designed for the Ibanez crew, so they sound "right" as an F spaced model. *Either way, its no real big deal.
Old 06-02-2001, 09:19 AM
bluenote  is offline
good point, frank
Old 08-01-2001, 02:46 PM
puppiesonacid  is offline
Posts: 61  -  iTrader: (0)
thanks for the clarification guys
bridge position, bridge pup, spaced pickup, standard neck, string pickup, string pickups
