<back   Jemsite > Jemsite.com Start Here > Archived Topics and Common Questions - GO HERE FIRST
Archived Topics and Common Questions - GO HERE FIRST Common topics/questions are archived here. You can reply but not start new threads here. NEW MEMBERS PLEASE GO HERE BEFORE POSTING a question after searching.
Old 07-02-2001, 07:25 PM
jemsite  is online
Administrator
Posts: 9,260  -  iTrader: (5)
Images: 11
Trem post set screws
post removed... loosen the set screw. You will have to tighten the set-screw so it loosens up and is free to move. The set screw should be able to protrude from the tip of the stud... glen
Old 07-02-2001, 07:28 PM
julio  is offline
Posts: 252  -  iTrader: (2)
I mean....
What do I do "now"?
Old 07-02-2001, 07:35 PM
jemsite  is online
Administrator
Images: 11
you must free the set-screw to move. to do that turn the set-screw clockwise.
Once free, *lower the screw until the tip just protrudes then back it off 1 turn so it is flush.
insert the stud, insert the trem, set the trem height then LOCK the set-screw (and stud)... glen
Old 07-02-2001, 07:36 PM
Kevan  is offline
deleted username
Posts: 1,429  -  iTrader: (0)
You have to "tighten" the SET SCREW. *(watch the first 4 seconds of the SET SCREW movie again). *This will loosen it from trying to be backed out the top of the TREM POST. *
The TREM POST is used for adjusting the bridge height. *
DO NOT try to use the SET SCREW to try adjusting bridge height (you'll either strip it out or see no results).
Once the desired trem height is achieved using the TREM POSTS, tighten the SET SCREW (by hand ONLY!)
Old 07-02-2001, 07:45 PM
julio  is offline
Thanks guys....but I´m not making myself clear
I´ve got the trem post in my hand ( out as in movie) but the set screw, will NOT turn either way. My hand is in a mess already.
It wont budge at all!!!!!
Old 07-02-2001, 07:48 PM
jemsite  is online
Administrator
Images: 11
try to force it loose. turn the set screw CLOCKWISE. Use a PLIERS to help turn the 1.5mm allen-wrench. If you break the allen-wrench, then you're out of luck... you will have to buy a new stud.
Alternate is soak the stud in oil overnight and hope it loosens up.
personally, i'd buy two new studs just for the sake of having a nice, new knife edge for the tremolo ... glen
Old 07-02-2001, 07:50 PM
julio  is offline
The set screw does not protude. Its end is just visible, as in ready to come out, but hard as a rock
Julio
p.s- and I´ve just given the WD4o back to my ex Damn
Old 07-02-2001, 07:51 PM
bachle7  is offline
Posts: 306  -  iTrader: (0)
WOW! *Those little guys sure are hard to explain, huh? *As soon as I took the post out of the body, the lightbulb flashed on. *"Screw-within-a-screw" is the best description I've seen.
I'm glad that so many others have "discovered" this. *Every other part of my guitar was fairly intuitive, but the set screws may be the Edge's best kept secret! *-Andy
Old 07-02-2001, 07:54 PM
bachle7  is offline
Julio, get on your knees and get the WD-40 back! *If you have the posts completely out of the body, then spray inside of the post if you can. *Using your 1.5mm Allen wrench, try working it clockwise, then counter-clockwise, etc. *With plenty of WD-40 in there, you should be able to gradually turn it more and more, one way, then the next. *DON'T TWIST TOO HARD, though.
Just make sure to wipe them down really well before putting them back in the guitar.
(Edited by bachle7 at 5:55 pm on July 2, 2001)
Old 07-02-2001, 08:01 PM
julio  is offline
I cant believe it!!!
The 1.5mm wrench has twisted around itself!
Hang on......
ALELUYAH!!!!!!
I´ve done it!!!! The wrench is now useless....but I´ve done it...
The set screw is loose, and now moves in and out!!
Thanks Glen/Kevan for the "live help line"
This is one great family
Julio
Old 07-02-2001, 08:12 PM
julio  is offline
Ooppps...
Sorry Andy ...Didnt mean to leave u out
Old 07-12-2001, 07:52 PM
jhczar  is offline
Posts: 14  -  iTrader: (0)
I had the exact same problem with my 1st Edge. *I posted here, and got a response in minutes. * Thanks guys! *Tightening the screws fixed my pitch problems immediately. *
On my 2nd RG, I received the original documentation and it specifies the existence of the set screws, but does not advise you to loosen them before adjusting the height of the trem. *
As an aside, I was going thru some old Guitar Player mag's a few nights ago, and in one of the '88 issues, they did a new product review on a JEM DY. *They specifically mentioned the set screws as one of the many new innovations that were included in the JEM series.
Old 07-26-2001, 02:18 AM
jemsite  is online
Administrator
Images: 11
Old 09-05-2001, 12:30 AM
YngVaiTriani  is offline
Posts: 548  -  iTrader: (0)
Where do I find info about trem posts... like if I want to swap a TRS with an Edge and I wanted to change the TRS posts to Edge.... is this it?
Old 09-05-2001, 08:48 PM
What's the deal with the set screws? Do they tigthen the posts of them trem or something? Please explain.....
I also need info on swapping TRS with with Edge posts. What's the deal? Size? Redrilling?
allen wrench, fret buzz, guitar tech, shawn lane, trem height
