Off-topic & Polls
Off-topic / Miscellaneous
car checkup
Talk about miscellaneous stuff off-topic and not related to music, guitars or bands.
No music, gear or anything guitar related here please.
07-30-2008, 05:22 PM
timi_h
Posts: 1,104 - iTrader: (
car checkup
evening all
Just about to do a long journey so i thought i would give the car a check over. Did all the tyre pressures, brake fluid, coolant, windscreen washer fluid and oil. Thats it all covered right?
Anyway, I accidentaly took the oil past the max mark on the dipstick - the "acceptable" range on it is about an inch and a half long and I went over by about a cm (sorry for the imperial/metric jumble, those are the most appropriate units for the respective distances!!) this shouldnt be a problem should it?
Cheers
timi_h
Find all posts by timi_h
07-30-2008, 05:57 PM
Canadian Mark
Posts: 435 - iTrader: (
Re: car checkup
A little over the line shouldn't hurt. What will probably happen is the excess will burn off (your exhaust might smoke blue for a little while). If you car already burns some oil, you probably won't notice anything.
If it is too full, the oil will tend to froth up and could cause more serious issues, but it sounds like you might only have about 1/2 a litre too much in there.
Good luck and have fun on you trip!
Canadian Mark
Find all posts by Canadian Mark
07-30-2008, 06:03 PM
funkdubious
Posts: 707 - iTrader: (
Re: car checkup
You got it right,but as Mark said if you over fill the oil it can go bang once the pressure gets up.Its happened to me,didnt cause any lasting issues but went all over the place and gave me abit of a fright as it exploded!
funkdubious
Find all posts by funkdubious
08-09-2008, 07:42 PM
bammbamm
Posts: 4,134 - iTrader: (
Re: car checkup
How often do you change the transmission fluid?
If you've never done it, depending on the age of the car. you do it for the 1st time at around 60K Miles and then every 30k after, or as needed.
Just looking, you're in the UK, I'm guessing you have a manual?
If so, just make sure the fluid is topped off. If you have an automatic, then make sure you change the fluid at the intervals I mentioned. (or follow the mfr's specs on that one)
bammbamm
Visit bammbamm's homepage!
Find all posts by bammbamm
08-09-2008, 08:33 PM
alex10
Posts: 698 - iTrader: (
Re: car checkup
Wouldn't make any difference mate,
In fact, most motocross riders (including me) run their bikes with a lot more oil than recommended, makes the clutch softer.
alex10
Find all posts by alex10
08-11-2008, 07:00 AM
eviltwin
Posts: 1,629 - iTrader: (
Re: car checkup
timi_h
how about checking some real wear items:
-tyres (thread depth, even wear)
-brake pads (if over 100.000km brake rotors as well) front AND rear
-handbrake (play/functionality)
-wiper blades
-battery
depends on the car, some engines are very susceptible to problems in this area. What make/model/type are you driving?
eviltwin
Find all posts by eviltwin
06:17 PM
