Off-topic & Polls
Off-topic / Miscellaneous
HDMI Connection
Talk about miscellaneous stuff off-topic and not related to music, guitars or bands.
No music, gear or anything guitar related here please.
12-21-2006, 04:46 PM
LethalAe86TypeR
Posts: 665 - iTrader: (
HDMI Connection
I got a problem with my HDMI connection now, when i turned the TV on, and theres nothing but sound comming out, and no video. At first i turned it on it says, there is a compromise with the HD connection and put it back to the old YPbPR cables. SO i did, the video is just rubbish, i want to use the HDMI, any suggestions? I tried to get to the setup by turning off the receiver then pushing menu, and it works then the tv blacks out again. I tried to set up on a different video with the YPbPR cables, but no HDMI setup. I got close i saw HDMI and UVI ( i think), i switched it to hdmi without the tv showing a picture, and it went on to the menu then blacked out again, then i switched it to UVI, then it went on then blacked out again. Is it my tv? Do i need set up the TV for HDMI? I tried to check the manual, and nothing about HDMI setup.
LethalAe86TypeR
Find all posts by LethalAe86TypeR
12-21-2006, 05:08 PM
elcid
Posts: 8,718 - iTrader: (
Re: HDMI Connection
HDMI sucks, nothing but problems. I cant count how many service calls I;ve had that was just a loose connection. If you can see a difference between Component and HDMI your eye must be better than
Eric Johnson
's ears. Telling us your equipment might help.
elcid
Find all posts by elcid
12-21-2006, 05:12 PM
LethalAe86TypeR
Re: HDMI Connection
You can tell the difference by alot. But thats besides the point. My Equipment is a Comcast Motorola HD-DVR reciever ( the silver one if it helps), and im running a HDMI cable straight into the HDMI Slot into a Sony Grand WEGA tv, and for audio, a red and white audio from the reciever to the TV.
LethalAe86TypeR
12-21-2006, 05:26 PM
elcid
Re: HDMI Connection
Hmmm, in my whole career I've never known anyone to see a difference (unless you are watching HD DVDs but thats not the point), why are you running analog audio cables in addition to the digital audio from the HDMI cable to the tv. That could be why you are getting audio and no video. Its also entirely possible the Comcast box doesnt support HDMI, I know they send out boxes with HDMI jacks, but alot of the early ones dont support HDMI. Its a problem I have run into alot over in Chicago. You also may need to turn on the HDMI jack on the TV
elcid
12-21-2006, 05:28 PM
LethalAe86TypeR
Re: HDMI Connection
I searched the manual for a HDMI option for the Grand Wega, and nothing. It was working before, but now it stopped. From another forum i was told " The latest firmware killed the DVI port on the box." would this be true?
LethalAe86TypeR
12-21-2006, 05:31 PM
elcid
Re: HDMI Connection
are you using HDMI or DVI?
It could be true, I'll never understand Comcast and the way they work.
elcid
12-21-2006, 05:46 PM
jemsite
Administrator
Posts: 9,271 - iTrader: (
Re: HDMI Connection
hdmi is a hassle for sure.... usually it helps to
* power everything off
* power on display/tv
* power on receiver/switcher and change to correct HDMI input
* power on source (cable box, hd-dvd player, etc.)
if it fails call and complain to cust. service. they need to get negative feedback to put a curb to hardware assisted DRM and pseudo security that does nothing except inconvenience paying customers... glen
jemsite
Find all posts by jemsite
12-21-2006, 05:50 PM
LethalAe86TypeR
Re: HDMI Connection
elcid
Well m uncle bought me the HDMI cable, and he says its HDMI. I connected it to the slot where it says " HDMI" on the reciever, then i add put the other side to the TV in the slot labled "HDMI"
this is the same cable im using
I cant find squat online for any HDMI stuff for my tv, i need help! LOL.
LethalAe86TypeR
12-21-2006, 06:07 PM
elcid
Re: HDMI Connection
thats a DVI to HDMI cable, that can easily give you issues with DRM an also explains why you need to run separate audio cables.
elcid
12-21-2006, 06:12 PM
LethalAe86TypeR
Re: HDMI Connection
DRM? What is it?
LethalAe86TypeR
12-21-2006, 06:16 PM
elcid
Re: HDMI Connection
Copyright protection.
elcid
12-21-2006, 06:23 PM
LethalAe86TypeR
Re: HDMI Connection
elcid
So what do i need to do about this? I'm need to go back to components?
LethalAe86TypeR
12-21-2006, 11:39 PM
elcid
Re: HDMI Connection
Sorry I didnt respond earlier, I was out guitar shopping. Anyway component would be your best bet
elcid
12-22-2006, 12:26 AM
LethalAe86TypeR
Re: HDMI Connection
I put my components back, and the picture is just crap. Everything is in a greenish tint. Anyone know whats up? If this helps im on a 16.2 firmware version.
LethalAe86TypeR
12-22-2006, 02:12 PM
fettouhi
Posts: 9,937 - iTrader: (
Re: HDMI Connection
elcid
From Microsoft
Regards
André
fettouhi
Find all posts by fettouhi
eric johnson
guitar shop
where buy lee perfect connection
192.168.1.1 is not set up to establish a connection on port "World Wide Web service (HTTP)" with thi
how do I add a firewire connection to my computer
sonic maximizer and rack connection
sanfender
Gear and Equipment
10:24 PM
ibanez heartfield talon connection
ps2@ec.rr.com
02:20 PM
hooking up 6 pcs to a broadband connection
John Finn
12:49 PM
Vai and Slash Connection??
Two hands31
Players, Bands, People, Music & Tours
09:14 AM
Neck-body connection
Screaming Wind
Tech: Setup, Repairs and Mods
09:52 AM
11:39 PM
