<back   Jemsite > Off-topic & Polls > Off-topic / Miscellaneous
Old 10-05-2007, 08:19 PM
TAorama  is offline
Posts: 1,762  -  iTrader: (8)
Home Theater Surround Speaker Location Advice?
I'm putting together a 7.1 surround system, and I need some advice regarding the location of the rear speakers. The room is very long, and approximately 20' wide. The screen is going on the 20' wall at one end, with the front speakers obviously pointing into the long length of the room. The surrounds will hang on the side walls, but I'm trying to decide where to mount the rear speakers. I can either put them further back on the side walls, or I can mount them on the ceiling. The room has about a 12' ceiling. I can't mount them lower, like on a table or something behind the seating area, and I'm concerned that the ceiling mount might make too much of an angle. If I put them on the walls, I'm concerned that the angle for rear speakers to the center of the listening area would be too great for the desired effect.
Any thoughts from the audio/videophiles out there?
Old 10-05-2007, 09:40 PM
Andy43  is offline
Posts: 814  -  iTrader: (5)
Re: Home Theater Surround Speaker Location Advice?
I haven't really experimented much, but it's supposably best to mount them about 6' high, so mounting them on a 12' ceiling would be too high.
Old 10-05-2007, 10:15 PM
jaxadam  is offline
Classified Watchdog
Posts: 3,045  -  iTrader: (9)
I've always heard better surround sound systems with the rear speakers at ear level when sitting down.
Any higher, and you're going to get reflection, and with the inherent delay in rear, it will have more interference.
I would just put them further back on the side walls.
Old 10-06-2007, 01:05 AM
jemsite  is offline
Administrator
Posts: 9,272  -  iTrader: (5)
Images: 11
that room is too large to concern yourself with perfect speaker placement. if your processor allows delay to each speaker you can get a balanced mix no worries.
where is the couch/seating in relation?
also are the speakers direct radiating or dipoles that scatter the surround?
i like surround next to the listener and rears behind & above the listener if the room allows it... glen
Old 10-06-2007, 01:52 AM
IbanezFreak777  is offline
Posts: 3,486  -  iTrader: (10)
Reviews: 24
Yeah I second the ear level position for rear speakers.
Old 10-07-2007, 01:01 AM
TAorama  is offline
Seating position is about 15' from the screen (a 10' projector screen). Surrounds will be right beside the seating area, ear level. That was the easy part. I'm still gear shopping, so I can't tell you for sure what the speakers will be. I was thinking about mounting the rears on the wall, same level as the surrounds, but pointing back toward the listener. If I did that, I'd go with direct radiators. If I mounted dipoles flat to the wall, like you normally would, then half the signal would just disappear in the back of the room (it's about 40' deep), I would think.
A guide to choosing tubes and cabinets! power freak Gear and Equipment 78 09-18-2011 11:35 PM
Post Your Home Theater jay ratkowski Off-topic / Miscellaneous 15 08-20-2007 12:34 PM
wiring for surround sound in home shredmaster Off-topic / Miscellaneous 22 07-02-2007 03:05 PM
Home Theater / Stereo <b>GilkyBear</b> Off-topic / Miscellaneous 14 11-19-2006 08:45 PM
Foam vs Rubber speaker surround x2n Gear and Equipment 14 09-09-2003 01:14 PM
