Originally Posted by guitarnutteruk
so basically there going to play gmajor over the progression.?
well they're playing C lydian over a C based progression. so they are playing in C lydian which is connected to G ionian with the same notes. but even when you're playing your G ionian shape, you're still in C lydian because that's what the key is based on(C lydian).
how could i stay in lydian over a verse or section of a song? is this where the base notes start coming into play?
well you could either play 'that chords lydian' over every chord (like Flydian over F, G lydian over G)
or do the usual thing like Vai etc which is to use the flavours of the other modes too by staying in one lydian key even over the other chords, technically giving you a different mode over each chord but that will add new feeling and flavours while feeling uniformly in the lydian based key..
also i though i could only play major modes like lydian over major chord sequences without effecting the mood of the mode.
yes you can only play C lydian over a Cmajor based chord
you couldn't then play A lydian over Aminor, but you could keep playing C lydian over A minor because they are connected, which would technically switch you into A dorian.
look at it this way. the modes are a template, all connected to eachother, and each mode has a type of chord it associates with.
so imagine that chord sitting on the first note of each mode..
(major chord for lydian, major chord for mixo, minor for aeolian, diminished for locrian, major for ionian, minor for dorian, minor for phygian, then you're back to lydian)
now that whole template can be lifted and moved around, and it's all one piece so the modes stay connected the same way nomatter where you drop the template
if you play a cmajor, you could place the template so the c ionian first note is over the C on the E string, then you're playing in C ionian.
or you could lift the whole template and drop it so lydian's first note is over C
now you're playing in C lydian,
and when you've placed the template you can see all the notes you can hit, from all the mode shapes, they are all still connected.
you can also see the relative chords for each mode moving, so if i place it so A Aolian is over A, then i can see i can play a C major where the ionian is sitting(over C) and then a D minor where the dorian is sitting(over D)
all the while my template is still sitting on A aeolian
then if i bump the template up a fret, my aeolian is now sitting over A# so i can now play an A#minor and solo in A# aeolian and i can see the chords i can work with have moved, the ionian's chord which was C, is now up one fret to a C#, so i can play a C#major, and the dorian's chord has moved up to D# so i can play D#minor
and over any of those chords i can solo playing all of A# aeolian, C# ionian and D# dorian's notes
the mode i'm technically playing in will change between those three only when the chord underneath changes.
