<back   Jemsite > Off-topic & Polls > Off-topic / Miscellaneous
Old 12-01-2008, 01:46 PM
adamcbest  is offline
Posts: 870  -  iTrader: (0)
networking Geniuses.. question
I have 1 wireless router right now. I have 3 units that are not within cable range of the router, that don't have wireless capability. Is there anyway to use another wireless router, or a wireless switch or something so that i can have that unit accept the signal, then send it to those units through cables? I know that having the three on one router will make the signal weaker to each unit, but only one should ever be actively using the network at any given time. basically i'm hooking a computer, Xbox, and Wii to the internet, but don't have anyway to get a cable to them.. I don't want to buy the wirless device for XBOX or the computer and for some reason the Wii will not connect to the wireless router i have even though my laptop will.
I appreciate any insight you guys may have.
Old 12-01-2008, 01:57 PM
jemsite  is offline
Administrator
Posts: 9,271  -  iTrader: (5)
Images: 11
Re: networking Geniuses.. question
if you can hardwire all 3 devices (i assume there in the same room) you only need a wireless bridge with 3 ports, such as the many examples here. this will give you full wifi access to your wireless router (which has your internet connection obviously) on the 3 devices without needing special wifi cards per device (xbox, wii, pc). you need 3 cat-5 cables also.
http://www.newegg.com/Store/SubCateg...ess-AP-Bridges
... glen
Old 12-01-2008, 01:58 PM
Algiman  is offline
Posts: 2,553  -  iTrader: (14)
Though about using something like this:
http://www.netgear.com/Products/Powe...Specifications
or this (if your router has a spare ethernet port):
http://www.netgear.com/Products/Powe...tAdapters.aspx
Old 12-01-2008, 02:19 PM
... glen
basically these three devices are all in a tv stand in the living room. They will all be hard wired. I have have a cat5 crimper and cable and ends are pretty cheap so the short cables i'll need won't be an issue.. The router is in another room, so if these access points work pretty well, i'll probably get one of those. I rent an apartment so i can't start adding cabling in the walls. That might make them a little mad. Plus they want a freaking fortune to have someone come in to do it.
Thanks for the suggestions
Old 12-01-2008, 02:28 PM
jaxadam  is offline
Classified Watchdog
Posts: 3,043  -  iTrader: (9)
Yup, just get a bridge with 3 ports, and clone the MAC address from your router into the bridge and you should be good to go.
Old 12-01-2008, 03:40 PM
jb4674  is offline
Posts: 4,010  -  iTrader: (0)
Reviews: 6
Why go through all that hassle instead of simply getting 3 usb wireless g adapters?
Seems like ya'll are trying to reinvent the wheel.
Jimmy
P.S.: Check that your encryption on the wireless router isn't set at 128-bit. I had that same problem with my ps3 and it wouldn't connect to my linksys router. In the end, I had to piggyback another wireless router to my linksys running 64-bit encryption so that it would connect (I'm lazy..).
Old 12-02-2008, 08:37 AM
so right now i have a belkin wireless N router that can be used as an acces point. It doens't have gigabit ports. I want to get a new router with gigabit ports anyway so that we could hook up a ReadyNAS Duo into my network for good storage/backup and quick access of our photography/other work from all computers. Seems to me i could just use my old router as the access point. thoughts.. Should the Belkin router be able to pickup wireless from any other brand of router?
Old 12-02-2008, 08:42 AM
Jimmy
from what i have heard the Xbox360 requires the use of MS's wireless device at 100 dollars. not even sure if it's a wireless N device. I can do an access point and cabling for less than that and only have to configure one wireless connection then.
if i had it my way every device would be wired. When i buy a house, it will be.
Old 12-02-2008, 09:35 AM
jb4674  is offline
Reviews: 6
That's not entirely true. I have a friend who was able to connect her pos xbox to her wireless router using an $8.00 usb wireless adapter she bought at Micro Center.
Jimmy
Old 12-02-2008, 10:18 AM
jemsite  is offline
Administrator
Images: 11
i don't have xbox but i don't see USB network card (with a generic driver) working very well, especially with security. I'd bet many people "connecting" with $8 adapters turn of WPA and run totally unprotected or WEP (also unprotected). That is not a solution imho.
The wifi router - to be a wifi bridge - needs to be able to work as a bridge. For example the D-Link DWL-2100AP has a bridge switch whereas many wifi routers won't necessarily be bridge-able (wifi to wifi). Other wifi routers can be a bridge simply by disabling DHCP on that device (using DHCP on the primary router to connect & obtain an IP).
download a user's guide & read/learn more
http://www.dlink.com/products/suppor...kInstallGuides
.. glen
Old 12-02-2008, 10:38 AM
jaxadam  is offline
Classified Watchdog
I agree with what Glen is saying. There may be a way to get it working, but it may not be the "best" way to do it, and it could leave your connection wide open.
I use one of these, and I just clone the router's MAC address in and it works as a secure wireless bridge for connecting things via ethernet.
It's actually just a wireless gaming adapter, but it will serve the purpose.
network
Wireless/Wired Router Networking Questions CosmicDebris Off-topic / Miscellaneous 8 04-12-2008 10:57 AM
networking computers John Finn Off-topic / Miscellaneous 2 07-04-2007 11:13 AM
f-space question, and pickup combination question Jing Tech: Setup, Repairs and Mods 14 05-03-2006 03:50 PM
777DY wiring question(parallel/series) +volume question mko Pickups & wiring 0 11-16-2004 08:06 AM
Question about ebay auction Question Miata1476 Vendors, Auction & Reseller Talk 6 11-12-2004 03:41 PM
