<back   Jemsite > Off-topic & Polls > Off-topic / Miscellaneous
Old 07-27-2006, 10:24 PM
EdE  is offline
Posts: 112  -  iTrader: (1)
Wireless network question
Ok so I finally got a wireless router. I have set it up to the point that I can access the internet with the laptop but I cant see the network. Also, in the router configuration window, I cant see the laptop (to get MAC address) to make it the only wireless device to be able to log on to the network. How do I get the router to recognize the wireless laptop so I can add to the Wireless card access list? I have a Netgear WGR614 and a Dell Inspirion 1505 if that helps.
I know I am missing something stupid but for the life of me I dont know what.
Thanks!!
Old 07-29-2006, 12:24 PM
shredmaster  is offline
Posts: 2,330  -  iTrader: (0)
Re: Wireless network question
to get pc's to see each other on your network at home they MUST be a member of the same workgroup. right click on MY COMPUTER, go to properties, click on COMPUTER NAME, then click CHANGE. make sure the computer name is there. i name it something so i know what pc it is on the network. then type in a workgroup name. this must be the same for each pc. also, click on MY NETWORK PLACES on your desktop. double click on network setup wizard. follow the prompts. you should be good to go. this all goes for winXP. good luck. after you do this you might want to consider setting up for mac addy filtering for extra protection on that wireless nic.
Old 07-29-2006, 12:39 PM
barbarelaxe  is offline
Posts: 906  -  iTrader: (12)
To find your laptops MAC address, on the laptop click start - run, type cmd and click ok. In the black window that will open up type: ipconfig /all
Look for the line that say physical address and thats the number your are looking for. IT should look like this: Physical Address. . . . . . . . . : 00-0D-61-2A-94-9D, with different numbers of course since every network card have a different MAC address.
Old 07-30-2006, 02:41 AM
Davey  is offline
Posts: 4,783  -  iTrader: (21)
Make sure to install the Netbeui protocol if you want them to see each and then follow shredmaster's advice. Sometimes it can be picky if it wants to see each other so once you've installed it on both machines, make sure to switch them both off then switch them back on.
Old 07-30-2006, 07:35 PM
EdE  is offline
So I am an idiot.
I cant get the thing to even connect to the network unless I have all the security disabled. Which I know I dont want to do.
I cant get connected to the router to even browse the internet.
I used WEP 64 encryption with a Key. I went to the Wireless connection properties, on the Association tab set Network authentication to Open, Data encryption to WEP, and entered the Key under network key. It still wont connect.
Any ideas? I tried calling NetGear but was on permahold. I couldnt find a Netgear forum either.
Grrrrrrr.....
Another wireless unit question adamcbest Gear and Equipment 0 02-26-2006 05:50 PM
Question about ebay auction Question Miata1476 Vendors, Auction & Reseller Talk 6 11-12-2004 03:41 PM
Tech question about my wireless? kennydoe Gear and Equipment 1 04-15-2003 01:14 PM
