<back   Jemsite > Off-topic & Polls > Off-topic / Miscellaneous
Old 04-06-2008, 11:12 PM
CosmicDebris  is offline
Posts: 3,216  -  iTrader: (4)
Wireless/Wired Router Networking Questions
In my home I currently have a wired network with a 4 port router. Really only our two desktops (one currently in a closet) need wires. No I don't need nor want to add a wireless card. My daughters and my wifes laptops can be wireless not to mention our Wii.
I strolled to best buy to check out what they had and all the wireless+wired routers were 4 ports. I want my desktop and our spare desktop to be wired thus taking up two wired ports on the back of the wireless wired router. That leaves three wirless devices that at one point or another will be acessing the router/internet at the same time.
My question is, in using the wireless part of the router does each wireless device take up a port in the 4port part of the router? So if I have my wired pc (1 used port) and three other wirless devices using the wireless part (3 ports) would another laptop like a friends of my daughters not be able to acces the router/internet because all 4ports were in use?
Whatever happened to two cups and a string?
Old 04-06-2008, 11:40 PM
RAI6  is offline
Posts: 217  -  iTrader: (0)
Re: Wireless/Wired Router Networking Questions
There shouldn't be a limit to how many items can access the wi-fi....
It's simply a signal that's being accessed.
Old 04-07-2008, 12:31 AM
jemsite  is offline
Administrator
Posts: 9,271  -  iTrader: (5)
Images: 11
like Rai6 said, 4-ports is 4 wired ports. there is no real limit for wireless connections so you're good to go.
if you need more physical ports (w/ cat5 cable) just connect any 5 or 8-port switch to the wifi router. you'll lose one port connnecting the new switch but will gain 4 ports (adding a 5 port switch) or 7 ports (adding a 8 port switch).... glen
Old 04-07-2008, 12:58 AM
jb4674  is offline
Posts: 4,010  -  iTrader: (0)
Reviews: 6
Actually, there is a limit guys. Cosmic, you have up to 254 ip addresses that your wireless router can dish out. Glen's idea for expanding the physical router ports is the best solution to tackle the lack of ports.
Jimmy
Old 04-07-2008, 04:36 AM
Excellent fellas, thank you very much.
Old 04-12-2008, 08:05 AM
DarthLamer  is offline
Posts: 108  -  iTrader: (0)
Jimmy
Wrong.
Old 04-12-2008, 09:48 AM
Originally Posted by DarthLamer View Post
Wrong.
A wrong without any facts backing it up is as water tight as a screen door on a submarine.
Old 04-12-2008, 10:45 AM
Nobody held my hand.
The information is available. If you are unable to find it, that's not my problem.
Old 04-12-2008, 10:57 AM
Fair enough I suppose. Thou it would make you seem like a nice person had you stated it in your post but that is neither here nor there. On a different note I found this picture of you very fetching.
The Router Duplicator courtney2018 Tech: Setup, Repairs and Mods 26 09-17-2007 05:01 PM
isp connectivity with wireless router issue shredmaster Off-topic / Miscellaneous 13 08-31-2005 12:12 PM
Interview with Andy Timmons - Questions? toneslave Players, Bands, People, Music & Tours 1 12-18-2003 11:03 PM
Some questions regarding/Wood/Bridges/finishes etc etc Swirly Tech: Setup, Repairs and Mods 16 12-16-2003 03:32 AM
Ibanez JS Questions!!! - Please answer these questions I hav Ibaman JS (Satriani Model) Ibanez Guitars 6 09-08-2001 03:10 PM
