Off-topic & Polls
Polls
Ibanez AT300 or Fender YJM
Polls
Create forum Polls here or vote in existing polls.
05-20-2007, 01:20 PM
SimpleMind
Posts: 151 - iTrader: (
Which one would you prefer?
SimpleMind
Find all posts by SimpleMind
05-20-2007, 01:24 PM
mi2tom
Posts: 7,522 - iTrader: (
Re: Ibanez AT300 or Fender YJM
AT300!!!
mi2tom
Visit mi2tom's homepage!
Find all posts by mi2tom
05-21-2007, 06:48 AM
BozTheK
Posts: 244 - iTrader: (
Well I have never played one but I heard from my guitar tutor that the YJM is fantastic, if set up properly. Of course, you need
heavy gauge strings
or it is likely that you will raise pitch if you press on the fret any harder than the tension required. But as I said, I haven't personally played it, so I don't know.
BozTheK
Find all posts by BozTheK
05-21-2007, 07:04 AM
EL-CeeDee
Posts: 484 - iTrader: (
I can only comment on the YJM, since I own one.
IF you get one, you will probably want to swap out the original pickups and
bridge saddles
The vintage bridge is very rough and "sticks" to your hand.
The pickups are fine, but are really low in output. REALLY LOW. They sound great once brought up to level by a booster, or whatever. But this also brings up the noise. The neck is great, IF you like thick necks. Don't even think about comparing it to an
ibanez neck
profile. Don't string it heavy, that will defeat the purpose. Just slap on some 9's. It makes you play lighter and thus, faster for a lot of people. The thing I personally love about the scallops is the crazy amounts of grip you have on strings while bending or executing vibrato. The trem system isn't worth much. I'm an avid trem user on my ibanez's, but on the YJM, the bar isn't even in and its screwed flat against the body. Due to the staggered middle pickup, I had to lower it, making the middle position of the 3-way switch useless. Inbetween settings ( 2 and 4 ) aren't notched, but are there. It's not a very versatile guitar, but the strange thing is..... I just can't put it down
I can imagine the AT300 to be more versatile. Probably a thinner neck profile. I just hate the way it looks ( the first AT ruled ! ).
Same thing seems to go as always : Try them both !
EL-CeeDee
Find all posts by EL-CeeDee
05-21-2007, 08:30 AM
neptoess
Posts: 303 - iTrader: (
as for the YJM. It's made for Yngwie. If you don't play like Yngwie or w/ a similiar setup to him, good luck. Although most shredders like paperthin necks, Yngwie uses a
vintage strat
profile. Most shredders like high output pups, Yngwie likes single coils. He also does use like 8-48s stringwise and only uses switch positions 1 and 5. As for the trem, it's just a strat vibrato, can't get too crazy on it.
neptoess
Find all posts by neptoess
05-21-2007, 08:46 AM
jemaholic
Posts: 2,806 - iTrader: (
Guys, the
YJM Strat
does not come with single coil pickups.
The saddle hex nuts can be raised or cut down so they don't scratch.
The middle pickup is not staggered.
....just setting things straight.
Thanks,
-jemaholic
jemaholic
Visit jemaholic's homepage!
Find all posts by jemaholic
05-21-2007, 10:59 AM
jb4674
Posts: 4,010 - iTrader: (
Reviews: 6
jemaholic
Guys, the YJM Strat does not come with single coil pickups.
Thanks,
-jemaholic
I'm not trying to be a smart-azz but, if the pickups aren't single coils, then what are these?
I'm sure the output problem could be solved easily. Most Strats don't have a high output to begin with, so I'm sure it sounds fine. I'm thinking that perhaps the pickups could be raised pretty high as well?
Personally, I would buy the YJM over the AT. The biggest difference you will encounter between the the two guitars is the weight. The AT probably weights just as much as an S series. I would probably get an SAS36FM and put the same pickups the AT has:
Jimmy
11:18 AM
jb4674
Find all posts by jb4674
05-21-2007, 11:30 AM
jemaholic
jb4674
Jimmy
YJM and HS-3 stack pickups are standard on Yngwie strats. These look like single coils but are really humbuckers...
jemaholic
05-22-2007, 03:40 PM
jwoods986
Posts: 378 - iTrader: (
Damn I miss my YJM
Obviously you can tell what my vote is -lol.
jwoods986
Find all posts by jwoods986
05-22-2007, 04:46 PM
spacestation
Posts: 71 - iTrader: (
The YJM is with out a doubt the best Fender guitar I've ever had or played and I've had tons of Strats. The scalloped board will take some getting used to but on the other had its well worth it. I wish all my guitars were scalloped like this (my other strat is). The pickups are weak as stated above. I have to use two different presets for each preset on my
Voodu Valve
- one for YJM and one for everything else. I can nail his tone (not his playing
) with this guitar. I did use a SD Hot Rails in the bridge for years but recently took it back to the stock configuration. I could live with just this guitar if I had to pick just one, but it would be a hard decision between it and the 550 RFR.
spacestation
Find all posts by spacestation
05-22-2007, 05:22 PM
EL-CeeDee
jemaholic
Thanks,
-jemaholic
Err... Hold on... Let me get my YJM handy..
Yes, they are single coils. But you are right, they are humcancelling. What is referred to as humbuckers nowadays is a double coiled pickup. The windings are wound around two core magnets. In a single coil, the windings are around only one coil. As is the case with the HS-3 and YJM pups.
So yes, they buck hum (
), but aren't humbuckers in the regular sense of the word.
( semantics, I guess )
The hex nuts can be raised or cut down. That doesn't change the shape of the saddles. The bent part stil "sticks". Stringsavers are flat/rounded squares.
The middle pickup IS staggered. I bought mine new. original pups. Maybe a spec change, unsure.
( On the dimarzio site, the same image is featured for the YJM and HS-3 pickup, in spite of the comment : "He also swears by our HS-3™, and he's always wanted a vintage magnet-stagger version to go with his best guitars." )
EL-CeeDee
05-22-2007, 05:48 PM
spacestation
I was under the impression that the YJM and HS-3 were "stacked humbuckers" as opposed to "side by side" 'buckers. And the fact that they are both 4 conductor type lead me to think that they are humbuckers. I know you can have 2 conductor single and 2 conductor bucker but I've never heard of a 4 conductor single coil. I could very well be mistaken though.
spacestation
05-22-2007, 08:23 PM
LynchBox
Posts: 70 - iTrader: (
Well, I am not a fan of the YJM, but I can tell you that when I worked in the
guitar shop
we would sell them as fast as they came in. They are a good seller for Fender. I think the longest we had 1 on the floor was a month.
LynchBox
Find all posts by LynchBox
05-23-2007, 06:59 AM
EL-CeeDee
spacestation
Yep, that's what I meant to say. They have all the properties of single coils, magnetic window, output and sound.
Still, wires around one vertical coil.
EL-CeeDee
05-27-2007, 08:24 PM
Darin
Posts: 2,459 - iTrader: (
AT300....it's on my hit list already. I would not buy any Strat for half the price of an AT300
Darin
Visit Darin's homepage!
Find all posts by Darin
alder body
bridge hum
bridge humbucker
bridge saddles
coil pickup
fretboard radius
gauge strings
guitar shop
heavy gauge strings
ibanez neck
jeff beck
jeff beck strat
vintage strat
voodu valve
yjm strat
yngwie strat
fender stratocaster + tremolo springs are noisy
ibanez 1570l discontinued?
how to set up fender trem
compare ibanez grx40 squier telecaster affinity
FT: Ibanez SZ520 for Fender Strat
lttoler
11:10 PM
Pictures from fender and ibanez factories
VaLDeZ
07:05 AM
WTT: Ibanez AT300 mint..
spindlergallery
06:39 PM
fs or wtt: Ibanez AT300 Andy Timmons signature model Mint!
spindlergallery
11:44 AM
Ibanez J-Custom & Prestige Overview and F.A.Q.
jemsite
01:48 AM
02:55 PM
