<back   Jemsite > Off-topic & Polls > Polls
Polls Create forum Polls here or vote in existing polls.
View Poll Results: Do you need highoutput pups for heavy distortion?
Definately, you need to push the amp. 3 16.67%
No, you need the tonal range of medium or low output pickups. 5 27.78%
It depends on how much versatility you need. 10 55.56%
Voters: 18. You may not vote on this poll
Old 02-25-2008, 11:42 AM
kotornut  is offline
Posts: 1,847  -  iTrader: (0)
Output matters?
Is it true that highoutput pickups aren't nesiscary with todays amps and gain levels? Please explain the reason for your answer if you can.
Old 02-25-2008, 01:18 PM
jono  is offline
Posts: 5,003  -  iTrader: (2)
Re: Output matters?
I voted "it depends". I think that there are so many ways these days to get a distorted tone, woods, pickups, pre-amps, pedals, amps and volume are just some of them.
Thus if you run a triple rectifier dialled all the way up, with a DS-1 in front of it and a boosted graphic equalizer, then a high output pickup might not be what you need. Alternatively if you're running straight into an old Marshall 1959 with no effects, you might want a little more umph straight from the guitar.
Old 02-25-2008, 01:45 PM
Myst and rain  is offline
Posts: 3,474  -  iTrader: (0)
Re: Output matters?
Yeah, I voted the third option, too.
Alwin
Old 02-26-2008, 01:41 AM
HeavyMetal4Ever  is offline
Posts: 1,172  -  iTrader: (0)
Re: Output matters?
What jono said.
Rock on!
Old 03-11-2008, 04:20 PM
losgatosrg350dx  is offline
Posts: 848  -  iTrader: (0)
Re: Output matters?
sometimes tho i found that its easier to remove some of the charachteristics and dynamics and tone from a high gain pickup rather than to have a low gain pup and trying to boost it
i can make my x2n sound closer to a evo, than making my evo sound like a x2n
also high gain pickups also offer characteristics wich can sometimes be of a good note, for instance some pickups have a higher natural compression....when in fact others dont
for instance if i send my duncan distortion or evo or breed into a noice gate, compressor limiter(etc)...i can actually hear the compression in a active state
if i send my x2n through my noise gate...i can almost never need a compresor for it
the dynamics it introduces into my preamp, are different than others, even when i had a carvin and i used duncan distortions in it before i got bartolini's, i had it go though a noise gate, compressor, eq and etc.... and it took all that to get me to my sound, but with a x2n i get what i want stock, and more, and i also can really fine tune the sound, cuz i just remove the frequencies i want or the charachterisits i want to emply on my signal, and i get a thick sustained tone
ive used a few preamps, but now i use a 2120 artist
Old 03-12-2008, 09:59 PM
elcid  is offline
Posts: 8,718  -  iTrader: (12)
Re: Output matters?
I've always been told the rule of thumb is either hot pickups with a low gain amp or a weaker pickups with a high gain amp. I'll see if I can find the whys in the old emails.
Old 03-13-2008, 12:38 AM
rickcard71  is offline
Posts: 1,803  -  iTrader: (1)
Re: Output matters?
I would have to say there are probably many different variations to that.
distorted tone, duncan distortion, high gain amp, output pickup, triple rectifier
Output Jack messed up? AKMG Other Ibanez Guitars (including Premiums) 7 02-07-2007 10:37 PM
Ibanez Factory Pickup Output Ratings? Big Red Other Ibanez Guitars (including Premiums) 7 04-05-2006 01:59 PM
your pre amp and poweramp output settings shredmaster Gear and Equipment 3 06-27-2005 07:30 PM
What´s the meaning of these output, resistence things ? Mandrak Pickups & wiring 1 11-29-2002 12:15 AM
Measuring pickup output - Particularly IBZUSA C1 & C2 JESTER700 Tech: Setup, Repairs and Mods 3 03-24-2002 08:54 PM
