Apart from the non-fitting issue, be also aware that the 707 can't be tapped, so you won't be able to get any sort of split-5 wiring. This will seriously limit tonal possibilities.
http://www.emginc.com/support.asp
Can I split the coils in my EMG-85?
No. With the exception of our pickups that have dual outputs, our active pickups only have 3 wires. As a result, coil splitting/tapping is not an option.
Furthermore, there is no 'single coil' EMG7
Do you make a 7 string single coil guitar pickup?
No, we do not. The only 7 string pickups made at this time are humbuckers;
So you would have to get a new pickguard, that can hold 2 EMGs , which would eliminate the problem of having a gaping hole where the Blaze single used to be
