Old 12-28-2007, 08:05 PM
djpharoah  is offline
Posts: 369  -  iTrader: (6)
Reviews: 5
AANJ vs Old School Joints - UV advice
I have always played an AANJ Ibanez RG7, K7 or whatever. However I feel my next guitar might be an old school UV.
How does the old neck joint compare to the aanj? I dont play that high that often but would like to when I can.
Just gimme comparisons I guess for the joints? Does it hinder your playing? Is it hard to get used to? etc... Is the 7th B harder to reach? Your preferences and which UVs you own.
I was looking o getting a green dot UV7bk or a UV7PWH, but then saw that the joint might not be as comfy as the aanj and am considering the uv777bk (with lopro - but chrome is so cheap looking)
Thanks
Old 12-28-2007, 09:15 PM
RG462  is offline
Posts: 507  -  iTrader: (0)
Re: AANJ vs Old School Joints - UV advice
AANJ gives a much easier reach to higher fret IMO. The Old style heel gives sexy curves to the body though !
Old 12-28-2007, 10:01 PM
jim777  is offline
I never had a problem with either. Actually, it took me a while to get used to the AANJ
Old 12-28-2007, 11:57 PM
brothersnowgone  is offline
Posts: 1,498  -  iTrader: (3)
Reviews: 7
Yep! The old joint looks better from the front of the guitar IMO, but it is a little restricting if your hands are small. For best feel though AANJ is next to a neck-through guitar which feels nice if you play on the upper frets more.
Old 12-29-2007, 12:18 AM
evolvedmb  is offline
Posts: 616  -  iTrader: (0)
I actually prefer the older neck joints over the AANJ myself. Reaching the upper frets is not really an issue with me, and I have smaller hands at 5'10"
Old 12-29-2007, 12:50 AM
surfdog777  is offline
Posts: 573  -  iTrader: (4)
I've got both, play all over the fretboard, and have never had a problem with either.
Old 12-30-2007, 05:09 AM
slash_88  is offline
Posts: 112  -  iTrader: (0)
i got two s series 540. one 540s with the square heel and the other is a s540 with aanj. i dont have problem reaching the higher frets on the e b g or d strings but strecting for the a and e strings around the 20-22 frets is abit hard.
Old 12-30-2007, 05:21 AM
JJEMMER777  is offline
Posts: 8,374  -  iTrader: (5)
Typical "old school" guy
For me (just IMHO) the AANJ gives much easier access to the upper registers. If you play one for a while and then go back, you'll see what I'm saying I still love the "old school" joints as well (and always will) but with the AANJ, less effort is involved, plain and simple!
Old 12-30-2007, 06:05 AM
Distantshore  is offline
Posts: 3,671  -  iTrader: (0)
Images: 4
I'm still laughing at "Old school joints"
Old 12-30-2007, 07:47 AM
eelblack2  is offline
Posts: 865  -  iTrader: (4)
Old UV's with square joints for me. The neck profile is to die for.
Old 12-30-2007, 08:07 AM
casper777  is offline
Posts: 331  -  iTrader: (1)
... and on top of that you have 2 types of AANJ... the regular one on prestige... and the GREAT one on J-Customs...
Old 12-30-2007, 02:02 PM
reguv760  is offline
Posts: 1,197  -  iTrader: (23)
Images: 5
Reviews: 12
it's always 4:20 at your place ain't it
I have average-sized hands and well, it somewhat hinders playing at the higher frets but it changed my playing technique. When I first got my UV777GR, I was perplexed by the flatter old style heel [not joint ] and this was my first 7 string I was going to get used to. I got offered a UV777BK to trade a week after owning it... I thought really hard about it and walked to the nearest GC to try one. The heel on the BK was much more comfortable... but the neck thickness/profile bothered me and wasn't going to be easy on my hands. So the GR stayed One of my friends has a BK that i get to play every so often and each time I reach the higher frets, my thumb kinda "remembers" there's a square heel when it's not really there... if that makes sense.
Otherwise, in terms of old school heels, there's the angled ones found in RG's then the flat ones found on Jem's and UV's. I've always thought the angled-ones were "better" but it doesn't make a difference nowadays since I don't place my thumb on the metal plate every time.
Reg
Old 12-30-2007, 02:28 PM
Dee  is offline
Posts: 8,514  -  iTrader: (2)
Similarly, there are different types of "old-school" joints, too (and this follows on from what judasbane was saying). The Early Jem/UV joint, the plain, Fender-style block joint, plus the "Tilt" joint of the RG550, etc.
I'd say that the early JEM/UV joint isn't bad at all. The old UV's are awesome to play, but compared to the Tilt joint found on the RG550, there's a massive difference between it and ANY AANJ. In other words, I wouldn't let the neck joint on an old UV be a factor in the purchase.
Old 12-30-2007, 04:53 PM
Ayrton  is offline
I have both, and really I have no preference. I doubt you will notice much if any difference after a few minutes of playing.
neck joint, neck joints, upper fret, upper frets
UV7 vs RG7620 Jem666Sk Other 7-string Guitars 52 07-05-2009 08:35 PM
Do RX AANJ necks fit AANJ RGs? slugman Other Ibanez Guitars (including Premiums) 4 03-19-2005 05:50 AM
WTT: Non AANJ UV neck for AANJ 7-string neck Platypus Classified Ads: Ibanez JEM/UV Guitars 0 11-15-2004 10:14 AM
UV777BK or RG2027x or 7VWH - need help deciding my first... 6stringsorcerer JEM and Universe Guitars 16 09-02-2001 11:32 PM
AANJ conversion on UV neck - has anyone tried it? Is it hard 7 Dying Trees Tech: Setup, Repairs and Mods 1 08-31-2001 06:44 PM
