Old 04-25-2009, 04:05 PM
RNRCRAZYKNIGHT  is offline
Posts: 84  -  iTrader: (0)
Another pickguard question...
I wanted to see if anyone knew the dimensions of a pickguard for a JEM? I have found the blue fluorescent material that will work for my DNA project. I'm just trying to figure out what size blank I should get.
THANX in advance for the help.
Scott
Old 04-25-2009, 08:48 PM
nato101010  is offline
Posts: 1,002  -  iTrader: (0)
Re: Another pickguard question...
Dimensions as in....? How thick is it? There's a lot of curves, so...
Old 04-26-2009, 04:49 PM
I need to know the thickness and how much overall space the pickguard takes up? Remember I'm buying a square/rectangular blank and it needs to be big enough to cut the pickguard out of.
Scott
Old 04-26-2009, 05:31 PM
korvus  is offline
Posts: 73  -  iTrader: (0)
Scott
Hi there, I'm sorry, I'm not going to help you... I'm going to ask you something :P What's the name of the material you found?
Old 04-26-2009, 05:36 PM
pilotfish  is offline
Posts: 140  -  iTrader: (1)
get a big one and you'll be safe! =)
Dont have anything to measure with but a standard a4 printer paper almost cover it... so add an one inch and that will cover for sure
Old 04-26-2009, 07:00 PM
I have found several places that sell an acrylic plexiglass material that is 1/8" thick and fluorescent. The material is see-thru also. I would put some links up; but I haven't posted on this board enough to do so.
Scott
Old 04-26-2009, 08:02 PM
korvus  is offline
Scott
so... it's regular acrylic plexiglass uh... I guess the only hard thing is getting the right color. I assume you've cut acrylic plexyglass before. But if you didn't... be prepared to buy more oh, and be carefull while cutting it, if you're using an eletric jigsaw be sure the blade is not too hot, or else you'll be cutting and fusing the acrylic back together!
Old 04-26-2009, 11:07 PM
I won't be the one cutting this. I'm going to leave it to an expert for that.
Scott
jem, pickguard replacing
pickguard question shrly1 Tech: Setup, Repairs and Mods 2 05-29-2008 10:13 AM
pickguard question phantoms Other Ibanez Guitars (including Premiums) 0 03-10-2006 09:44 PM
Jem Pickguard Question bluealien JEM and Universe Guitars 3 02-07-2006 12:21 PM
DNA Pickguard Question jay ratkowski JEM and Universe Guitars 18 10-04-2001 02:48 PM
