Any problem setting up for BEADGB? - Any problem setting up - Jemsite
post #1 of 3 (permalink) Old 06-28-2001, 08:31 AM Thread Starter
I'm a new Jem owner and I am wondering if there will be any problem setting up with heavier strings for BEADGB tuning. *My main concern is with the ultra thin neck. *Any and all help greatly appreciated. *Thanks.
-Ben
Pudreaux is offline
post #2 of 3 (permalink) Old 06-28-2001, 01:58 PM
Even with heavier gauge strings they'll be a bit floppy (sp?). Why didn't you buy a Universe ?
Mirrored CAT is offline
post #3 of 3 (permalink) Old 06-28-2001, 02:56 PM
I set up my RG for BEADF#B, and have no problems, I use the bottom 6 of D'Addario 54-9 7 string sets.
A bit floppy, but not buzzy, nomore than my UV. Just make sure you set the intonation for the heavier guage.
Anonymous is offline
gauge strings
Human Verification
Ibanez 1527 setting up problem ArmorDarks Archived Topics and Common Questions 11 04-01-2012 08:52 PM
which ohm setting to use? RI_RGplayer Gear and Equipment 6 10-22-2010 01:50 AM
I KNOW VAI'S SETTING!!!!!! Jslegacy Gear and Equipment 40 11-22-2003 09:33 PM
Setting Up - Seriously need some help here Scoff X Tech: Setup, Repairs and Mods 1 03-15-2002 10:41 PM
Problem about setting String Height of my PGM cowcowcow Tech: Setup, Repairs and Mods 7 01-19-2001 09:32 AM
HTML code is On
