Old 04-02-2009, 05:46 PM
nato101010  is offline
Posts: 1,002  -  iTrader: (0)
Building My 1st Geetar.
I have decided to build a Jem style guitar. I have a few questions. I've looked at Project Guitar.com a lot, but I need some help with the neck part of it. I want to use Stew Mac for a neck, as I will buy a Finger Board with the nut and frets cut out already. I have a great wood worker which I'm very close to, so he is going to help me, but...
I'll shape the neck a "blank", cut out the truss rod with a router, but that "blank" looks too small. Please tell me that it is bigger then in the stock photo?
And, for the "Hod Rod 2-way" truss rod, wouldn't the routing be easier, as its straight down the neck and doesn't get deeper as it gets down the neck?
I want a square neck pocket, (it will be sanded down like the old Jems), does anyone have the neck pocket measurements for an old Jem?
And finally, what color should it be? I was thinkin' a DY or LNG.
Thanks!
Old 04-02-2009, 06:05 PM
Jaden  is offline
Posts: 2,464  -  iTrader: (7)
Re: Building My 1st Geetar.
the hot rods are deep ie; thye require a deep channel to be routed - check th0e specs - you wont get an original jem profile if you use ene of them.
the 2 way rods that luthiers mercantile sell are better.
I dont know what neck blank you are looking at but it only needs to be 20mm thick at the heel - the thickest part.
Old 04-02-2009, 06:23 PM
I don't want a Jem profile. Ok, thanks. It its only 20mm I shouldn't have anything to worry about. Its 13/16''.
Old 04-02-2009, 06:26 PM
barbarelaxe  is offline
Posts: 906  -  iTrader: (12)
Go here: http://www.jemsite.com/jem/20-ibanez...f-the-jem.html and scroll to the buttom. there are a couple of blueprints of a square neck joint jem body with all the correct measurements.
Old 04-02-2009, 06:52 PM
OK, I found something a little clearer on Stew Mac. Thanks. One more question, what's flat sawn and quarter swan, and what are the pro's and con's of each?
Old 04-02-2009, 07:18 PM
brothersnowgone  is offline
Posts: 1,498  -  iTrader: (3)
Reviews: 7
pro: quarter sawn
con: flat sawn
https://www.musikraft.com/htmdocs/htmimages/FSQS1.jpg
The "slab cut" piece is the flat one. Quarter sawn is more stiff and stable compared to flat.
Old 04-02-2009, 10:04 PM
Ok.
But that link doesn't work.
build, custom, guitar, jem
You know you wants this geetar! lloop9 Other 6-string Guitars (non-Ibanez brand) 23 04-29-2009 12:00 AM
My new geetar!! Serratus JEM and Universe Guitars 54 08-19-2007 01:56 PM
Me playing my geetar alex10 Multimedia: Music, Pictures & Sounds 20 06-29-2007 12:08 PM
Need some help choosing a geetar! jamiewitt1 J-Custom, USA Custom & Prestige Ibanez Guitars 12 03-30-2006 06:26 PM
