Entirely possible. I'd use a push push pot as the knobs on most jems are stratlike and come of with pulling the putton up all the time.
But yes, it's very easy to do. With a bit of thinking you can wire it so that you can split both humbuckers, and phase reverse the neck. You can do loads as long as the wirting is kept neat as front mount electrics can be a bit of a bitch to fit if there's too much stuff in there!
But yeah, what you're wanting to do is fairly easy
