Old 05-04-2009, 12:06 PM
ecsong187  is offline
Posts: 16  -  iTrader: (0)
Difference between Original Vs. Reissue 77FP
So I'm looking for a Jem and not having much luck on here. I was browsing CL and came across an ad where a guy stated he had a 77fp reissue for $1200? I never knew their was a reissue? What are the differences between the original and reissue? How much are the reissues worth?
Thanks
Old 05-04-2009, 12:27 PM
djohns74  is offline
Posts: 580  -  iTrader: (0)
Re: Difference between Original Vs. Reissue 77FP
The 77FP re-issue was for the 15th anniversary of the original and was sold in 2003. Differences that I'm aware of were the new-at-the-time Edge Pro and AANJ. I think everything else was essentially the same as the original. As far as value, I really couldn't say, but $1200 for one in good condition certainly seems reasonable to me, assuming everything's legit.
Old 05-04-2009, 12:30 PM
yea thanks i had to search a while but found a little bit of info that states really the only difference is the Edge pro
Old 05-04-2009, 01:06 PM
DEADTUNES666  is offline
Posts: 2,174  -  iTrader: (1)
Reviews: 12
Red face
There is, in my opinion, some magic associated with the originals...
Maybe I'm nuts but I swear when I play newer Jems against the originals, there is a certain quality that the newer ones just don't have...
Old 05-04-2009, 02:15 PM
djohns74  is offline
Well, sure, I can see that. It's likely that production techniques and/or materials used were slightly different, and it's also possible that the oft-mentioned "mojo" of the older instrument makes it somehow superior, and it's also possible that it's all in your head. Any of these three is equally likely, and also equally valid.
Old 05-04-2009, 02:25 PM
yea personally I could care less if it's the original. i just want the guitar and if I can save $1k buying a reissue I'll be happy. because i'm buying mine mainly to play not as a collectors piece.
thanks for the great input guys
Old 05-04-2009, 02:34 PM
Rich  is offline
Age?
The term reissue started with the 99's, for whatever reason. It's not like production ever stopped. Ask for the serial number, that will tell what year it is if you care. Otherwise, other than the 15th which has an Edge Pro [and no FP has the AANJ] the only differences will be direct mount pickups / guard mount, Edge / Lo Pro / Edge Pro, where the volume knob is.
Old 05-04-2009, 02:41 PM
djohns74  is offline
Ah, I remembered that one incorrectly. Also, I do find it a little weird that they'd put the Edge Pro on it, but not the newer neck joint, which by the time of the 15th was already 10 years old.
Old 05-04-2009, 03:05 PM
here is the serial number guys. What year would this be?
263543
Old 05-04-2009, 03:12 PM
Rich  is offline
The serial number is on the headstock.
Old 05-04-2009, 03:32 PM
serial number is 263543
Old 05-05-2009, 09:33 PM
tulips777  is offline
Posts: 37  -  iTrader: (0)
I used to have a Jem77FP Reissue. But I had to sell it a couple years ago. It was One of the best and beautiful guitars I ever played. I still miss it very much. Also like the fact that it was a lot newer and "fresh" compared to an original.
Old 05-05-2009, 10:11 PM
LonePhantom  is offline
Posts: 5,366  -  iTrader: (6)
Reviews: 98
That's not the correct serial number. The serial number on the back of the headstock should start with an "F".
Old 05-06-2009, 12:20 AM
elcid  is offline
Posts: 8,718  -  iTrader: (12)
Maybe that's why he's asking $1200 instead of the usual $2300+
FS 1987 All Original Parts With Case Jem 77FP Dualchambers Classified Ads: Ibanez JEM/UV Guitars 1 03-14-2008 04:47 PM
Difference original and replica? Pox JEM and Universe Guitars 27 12-01-2006 12:43 AM
Sound difference between Rocktron Voodu Online and Original? jpwannabe Gear and Equipment 2 03-30-2004 01:06 AM
MutronIII original vs. reissue SilverSurfer2 Gear and Equipment 0 03-02-2004 08:01 PM
How to differentiate between an original TS9 and a reissue? Jeff Gear and Equipment 1 01-19-2003 03:35 PM
