Old 12-17-2006, 02:03 AM
Rich  is offline
Posts: 19,350  -  iTrader: (21)
Re: edge pro to lo pro
Originally Posted by thelegacy View Post
Okay.... I do hate it when I spend $1400 to prove Rich right.
I tried to tell you, I did the swap both ways long ago when it was a heated topic, and I dare say if you try another VWH body you'll find out while it may fit in that one it won't [be useable without modding] in another. The block is nearly twice the size on an EP as the ED/LP block.
Old 12-17-2006, 03:49 AM
thelegacy  is offline
Posts: 479  -  iTrader: (0)
Want a deal on JS1000????
I think I'll keep if for awhile.
Old 12-17-2006, 03:53 AM
Rich  is offline
Ever hear the term "return"?
Old 12-17-2006, 08:44 AM
fettouhi  is offline
Posts: 9,937  -  iTrader: (2)
Originally Posted by Ke^in View Post
ew .wmv
Regards
André
Old 12-17-2006, 10:46 AM
That's why I said I'd keep it for awhile. Awhile being 29 days!
Old 12-17-2006, 11:12 AM
dex  is offline
Posts: 1,972  -  iTrader: (3)
This was the only major issue we came up with back in the day - the ears in the side of a Edge and Lo Pro Edge go all the way forward to where the baseplate ends.
It's quite clear from the pic that this specific guitar will need routing to accept an Edge or a Lo Pro Edge.
Either that or you'll have to file said years on your Lo Pro Edge to make it fit.
Second point is the underside of the new trems is much chunkier and like Rich said fitting it is a gamble.
It might fit, it might not.
make sure to click on the "full size" option on the top left.
By the way as you can clearly see there an EDGE trem will ABSOLUTELY NOT FIT in an Edge pro cavity without the lions claw as the string lock screws stick out too far.
Old 12-20-2006, 12:19 AM
guitarman13  is offline
Posts: 388  -  iTrader: (0)
So even with a JEM7VWH you couldn't swap the edge pro for an original edge without routing?
Old 12-20-2006, 07:50 AM
fettouhi  is offline
Pushing it to the limit .
Regards
André
Old 12-23-2006, 09:21 AM
slash_88  is offline
Posts: 112  -  iTrader: (0)
so how abt ep2 to edge will i neeed any routin work?i got a jem 555 with the ep2 and im gettin an edge soon will it be a direct fit?
Old 12-23-2006, 09:46 AM
dex  is offline
It's a gamble. It might work and also might not but if the ears of the Edge are the only thing in the way (you'll know as like Rich said the trem won't go forward enough for the knives to sit on the posts) like you can see from my pic then just file them a little rather than route the guitar.
About the Edge Pro II to Edge I'd say no or at least you won't be able to pull up because the string lock screws on an Edge stick out too far back so they'll dig into the lions claw.
Again - trying it is the only way to find out for sure.
Old 12-23-2006, 10:32 AM
jb4674  is offline
Posts: 4,010  -  iTrader: (0)
Reviews: 6
That's why Joe had his 1200 routed for an Edge.
http://peavey.com/images/extras/wall...sx_02_1024.bmp
Jimmy
Old 12-23-2006, 07:45 PM
fettouhi  is offline
Jimmy
Yeah but on the new Live DVD he's using a JS with an Edge Pro.
Regards
André
Old 05-11-2011, 03:54 AM
Gastricsumo  is offline
Posts: 25  -  iTrader: (0)
I know this is an old thread, but I just had to comment on something. I bought a jem body project (alder) and was told it was for edge and lo-pro edge. I had a rg1550 that I wanted to use for parts (edge pro)for the maple neck and to make a natural out of it. I did the swap, and it came out looking pretty sweet. The body was apparently routed for the old style neck (56mm?) but the new prestige necks are a bit wider (58mm?) so had to sand a bit off each side to make it fit.
The first issue I had with the trem was that I couldn't get the action low enough to match my real jem.
I had the bass side trem adjustment screw bottomed out, and the treble side nearly bottomed out. In addition, there was only a tiny bit of pull up ability.
The first thing I did (since it was a natural) was take the trem out and sand a couple millimeters of wood from the back route where the trem block was hitting the wood. Took me a while, but it worked well, and now I had normal pull up ability and can't even really tell I did any sanding.
The second thing I did was shim the neck with a brass shim. This brought the neck angle up, but I had to back out the trem height adjustment screws a couple turns to get it playing with really low action like my original jem.
But I discovered the intonation was off, so I adjusted it, and the high "e" saddle ended up moved forward to the point that it is hitting the pickguard. So now I may have to cut a bit of the pickguard to make it work.
Oh well, I'm still working on it, and I'll see if I can get it adjusted right. Maybe I'll try a smaller shim and lower the trem a bit to see if I can get it intonated.
I'll update how it ends up when I get it there.
aanj neck, aanj neck joint, custom jem, double neck, edge pro trem, edge trem, edge trems, ibanez trem, neck joint, neck joints, pro edge, steve vai, string lock, trem arm
Edge III swap for another Edge model trem? lespaulreedsmith Other Ibanez Guitars (including Premiums) 36 03-14-2009 06:10 PM
Edge mysteries solved!!......? - Answers to some common ques Jason Stone Tech: Setup, Repairs and Mods 18 05-27-2008 09:35 AM
I just put an Edge in my RG470! DirtyBird31 Tech: Setup, Repairs and Mods 10 09-14-2007 12:22 AM
edge, lo pro and edge pro are 100% drop in fit dex Tech: Setup, Repairs and Mods 47 10-18-2005 12:29 PM
lo pro edge vs edge pro 7 cakewalkr7 Tech: Setup, Repairs and Mods 4 02-11-2005 12:23 AM
