Old 03-03-2008, 03:34 AM
musbing  is offline
Posts: 7  -  iTrader: (0)
Smile
Egde Pro on JEM-555WH
Hello,
for my Ibanez JEM-555WH (2006)
is it possible to install a vibrato EDGE PRO on my guitar ?
because my vibrato EDGE PRO II is 'tired'
the ARM is too Floating
Thanks,
mb
Old 03-03-2008, 03:53 AM
rob777vdy  is offline
Posts: 2,575  -  iTrader: (3)
Images: 3
Re: Egde Pro on JEM-555WH
i had a 555 for 11 years.spent most of that time tuning in (lo-trs11).i swapped it for a line6 flextone amp ahhhh best thing i ever did.
Old 03-03-2008, 04:36 PM
isaac  is offline
Posts: 63  -  iTrader: (2)
an OFR is a direct swap..youre better off with that cause you have to route wood for an edge pro
Old 03-03-2008, 08:51 PM
albee1952  is offline
Posts: 784  -  iTrader: (2)
isaac is correct. I have done this mod but if you are not really good with routing, I recommend you do not attempt it. If you want to details, shoot me an email.
Old 03-03-2008, 08:52 PM
rvai  is offline
Posts: 458  -  iTrader: (0)
yu don´t have to rute for an edge pro but yo do have to if you put an OFR there
Old 03-04-2008, 02:42 AM
musbing  is offline
thanks for you reply,
OFR = Original Floyd Rose
Schaller is the manufacturer ?
http://schaller-guitarparts.de/hp263...los-_-Nuts.htm
What's model, “Floyd Rose” Tremolo or Low Profile Tremolos ?
Old 03-04-2008, 03:46 AM
musbing  is offline
On this site he speaks of a swap of vibrato ibanez
http://lawl.net/gtr/trems
LoTRS I/II: most famously known to be replaced with the Original Floyd Rose or Gotoh FR. If you are replacing the studs, you will need to drill your guitar to accomodate the new bigger studs.
Edge Pro II: swaps with the Edge Pro. The locking stud mod is also recommended.
Edge III: swaps with the Original Floyd Rose. Stud rule applies, OFR studs are bigger. Additionally, there is a variation in Edge III routes that prevent the easy swap in some series.
Old 03-04-2008, 08:02 AM
Glados  is offline
Posts: 53  -  iTrader: (1)
Not correct i have a 555 with OFR No probs just insert it no routing or changeing Studs... Will fit right in...Stayed in tune for 6 month now and still are.
Old 03-04-2008, 08:41 AM
musbing  is offline
Hello,
your Trem is Original Floyd Rose (see the model) ?
http://www.floydrose.com/original.html
It is important to have the right model...
Old 03-04-2008, 06:12 PM
Glados  is offline
Originally Posted by musbing View Post
Hello,
Hello
Yeah i have the same as van Halen had.
It was on a 80's kramer the OFR is Made in Germany.
Mrvai said you have to route the swap to OFR on a 555 And i said for OFR you can put i right in... Thats it.
Old 03-19-2008, 04:31 AM
trixdropd  is offline
Posts: 9  -  iTrader: (0)
i bought a lo pro edge on evilbay and it fit right in my jem 555bk from 1996. Holds tune just fine...
Old 03-20-2008, 12:36 AM
Claudio Passamani  is offline
Posts: 90  -  iTrader: (0)
Images: 2
Here is my 555. changed the trs for an edge tremolo. now i call it JEM557
Old 03-20-2008, 05:24 AM
groove87  is offline
Posts: 59  -  iTrader: (1)
the edge tremolo work's without modification?
Old 03-20-2008, 01:26 PM
Images: 2
well here it fits normally without mods.. i heard that we have to change the studs and remake the stud holes.. but i gently put the edgre on the trs studs and the thing worked.. the tremolo dont touch the wood and the screws fit in tremolo cavity.. that peculiar "slap the whammy bar" effect, so good in the edge tremolos are not so efective.. im considering change the studs too.. but the guitar is working on tune.. perfectly..
Old 03-20-2008, 02:48 PM
jb4674  is offline
Posts: 4,010  -  iTrader: (0)
Reviews: 6
Wrong.
Wrong.
The swap to an Edge Pro is the most logical one if the guitar is equipped with an Edge Pro II. The swap is doable because both trems are similar in dimensions and the route is the same.
Jimmy
edge trem, floyd rose, ibanez edge pro, ibanez jem, kahler trem, locking stud, locking stud mod, pro edge, tremolo cavity, trs bridge, van halen
Who to sharper a knife egde
Transcript of Aussie Vai I'view (didnt know where to put it) TheOrangeChannel JEM and Universe Guitars 16 07-26-2006 12:52 AM
F/S or trade jem 555wh steve vai 777 Classified Ads: Guitars and Gear 6 03-06-2005 03:18 PM
Greetings, from this new JEM owner! kingtj JEM and Universe Guitars 7 08-11-2004 01:45 PM
Nice story to tell - How I've found a JEM 10 jember JEM and Universe Guitars 9 03-20-2002 06:22 PM
A little problem with my JEM 555WH - I've already seen this carlos seo JEM and Universe Guitars 8 03-01-2001 12:54 PM
