EVO's and Pinch Harmonics
06-04-2006, 05:11 PM
guitarman13
Posts: 388 - iTrader: (
I recently got a JEM7VWH and I've discovered that some
pinch harmonics
on the third string, are hard to get and fade out quickly. When I get a pinch harmonic on the 9th or 14th fret of the G string and use vibrato, the harmonic fades away. Is this just how EVOs are?, because I have EMG-HZ pickups in my Jackson and pinch harmonics are extremely easy to get and don't fade away quickly. Why are pinch harmonics crappy only on the third string?
guitarman13
Find all posts by guitarman13
06-04-2006, 05:14 PM
Jaden
Posts: 2,464 - iTrader: (
Re: EVO's and Pinch Harmonics
guitarman13
I recently got a JEM7VWH and I've discovered that some pinch harmonics on the third string, are hard to get and fade out quickly. When I get a pinch harmonic on the 9th or 14th fret of the G string and use vibrato, the harmonic fades away. Is this just how EVOs are?, because I have EMG-HZ pickups in my Jackson and pinch harmonics are extremely easy to get and don't fade away quickly. Why are pinch harmonics crappy only on the third string?
+1 - happens to me too
Jaden
Visit Jaden's homepage!
Find all posts by Jaden
06-04-2006, 05:15 PM
guitarman13
Is that just normal, or is it something like a
truss rod adjustment
? Because it's sorta annoying
guitarman13
06-04-2006, 05:22 PM
toneboy
Posts: 1,665 - iTrader: (
Have you tried lowering the pickup a bit? If the pickup is too close to the strings, the pickup's magnetic field can actually dampen the string's natural vibration and affect sustain. A pinch harmonic doesn't vibrate the string that much to begin with.
toneboy
Find all posts by toneboy
06-04-2006, 05:28 PM
guitarman13
Yes actually, I did try that. It seems like it helped a little bit, but the problem is still there.
guitarman13
06-04-2006, 05:33 PM
Jaden
yea, strangely, I get much better sustained harmonics from the top E string than I do from the G-string
pretty strange cos every other guitar I have is the opposite...
in short, I dont know what causes it
Jaden
06-04-2006, 06:25 PM
SonataGuitarist
Posts: 408 - iTrader: (
My Evo has pinch harmonics out the a$$ (couldnt resist saying that)
Are you still on the same set of strings that came w/ the guitar? Perhaps the string is at fault. A new set might clear it up.
It's just a suggestion, Ive yet to be dissapointed w/ evo, i get my best PHs at the 4th fret on the 3rd string(or maybe it's just the one i enjoy the most).
Although I enjoy them all
PHs rule.
SonataGuitarist
Visit SonataGuitarist's homepage!
Find all posts by SonataGuitarist
06-04-2006, 07:17 PM
guitarman13
I lowered and raised the pickup over and over and I finally solved the problem. I'm sure after I perfect the intonation on that string that it will help even more. The EVOs are awesome pickups. The pinch harmonics sound so tasty! Thanks for all of your advice everyone.
guitarman13
06-04-2006, 09:12 PM
ibanez2005
Posts: 910 - iTrader: (
I think this is down to player technique, when i got my 1550 i found i had the same problem, sorted it now though.
ibanez2005
Visit ibanez2005's homepage!
Find all posts by ibanez2005
06-05-2006, 02:21 AM
btangel
Posts: 541 - iTrader: (
Most of the time it's the rest of your stuff. Digital modeling stuff (ie. POD) have a hard time with pinch harmonics. At least from my experience, I have a analog DS pad in front and it helps a ton.
btangel
Visit btangel's homepage!
Find all posts by btangel
06-05-2006, 03:50 PM
rastachild
Posts: 720 - iTrader: (
btangel
i've never had any problem with pinch harmonics using digital modelers. must've been the setting you were using.
rastachild
Find all posts by rastachild
06-05-2006, 07:03 PM
red5
Posts: 2,639 - iTrader: (
When I have problems getting pinch harmonics, it's because I'm not doing it right. And then I focus on what I'm doing, do it right, and I know it
red5
Find all posts by red5
06-08-2006, 10:12 AM
Shredder87
Posts: 417 - iTrader: (
+1... I am crap at doing PH's! Badly need to learn the correct technique.
If it's just happening on 1 string, try adjusting the individual pole pieces on the PUs. That might help a bit.
Shredder87
Visit Shredder87's homepage!
Find all posts by Shredder87
06-08-2006, 12:17 PM
btangel
rastachild
To each their own I guess, but I've noticed that digital stuff doesn't respond to PH as well as analog. It'll scream, but with less intensity and duration.
btangel
06-08-2006, 10:30 PM
speedy mcfeely
Posts: 293 - iTrader: (
I wonder if you could get
Zakk Wylde
to try out your jem. That would be the test, he can't help but do pinch harmonics.
Try adding a little more mids to your set up, and try again. EVOs are pretty scooped.
speedy mcfeely
Find all posts by speedy mcfeely
pinch harmonics
rod adjustment
tone zone
triple recto
truss rod
zakk wylde
how to satriani harmonics
what string gauges a best for pinch harmonics
what does pick harmonics mean
can you do a pinch harmonic on a violin?
how to play the harmonics for blurry
guitarman13
Pickups & wiring
05:52 PM
03:03 PM
