Old 04-20-2008, 05:00 AM
mooro  is offline
Posts: 167  -  iTrader: (5)
Evos' vs Paf Pro
After a bit of help from you guys....
Now that I have taken all that gold hardware off my jem 7vwh and started playing it again, I am finding that i have to back off to 1 on the volume before there is a noticable clean up of the sound. (Semi high gain on a fender supersonic) On my pgm, which i have sold and ships on tuesday, which has on it paf pro's there is much more flexiblity and cleans up much earlier giving a bit better tone.
Do you think this is just because of the power difference in the pickups, does it have different volume pots or because the pgm is a solid block of wood without the trem? Any ideas ? both guitars have 10 gauge strings on
Any advice appreciated.
Cheers
Peter
Old 04-20-2008, 05:54 AM
AleTheNervo  is offline
Posts: 459  -  iTrader: (0)
Re: Evos' vs Paf Pro
It's because of the output of the pickup, but you could try also with a non linear volume pot
Old 04-20-2008, 06:45 AM
Algiman  is offline
Posts: 2,552  -  iTrader: (14)
If you have to go all the way down to 1 to get a noticeable change in sound you are either using some ridiculous amount of gain or your vol pot is knackered.
Sure, the Evo is higher output than a PAF Pro, but it isn't going to make as much difference as you are describing. As far as I'm aware the Jem and the PGM use the same vol pot.
Some things to consider:
Do you get the same problem on the neck pick up? The PAF Pro is actually slightly higher output than the Evo neck.
Does the volume change significantly as you role the vol pot down whilst using an uncompressed clean sound? If not, the pot is knackered.
Old 04-20-2008, 08:29 AM
JJEMMER777  is offline
Posts: 8,374  -  iTrader: (5)
Quite possibly. On my rig, the PAF's are brighter (louder) and I find I need to back them off a bit vs. the Evo's
Old 04-21-2008, 10:33 AM
mooro  is offline
cheers for the advice guys. I have new amp since I last had the jem out, and have played around with the clean channel to get to the bottom of the problem.....
The neck evo is fine, but the bridge does have pretty big step up in volume compared to my pgm. Its off the the trades now for a weaker ladies 'humbucker lite'!
gauge strings, neck evo, paf pro, volume pots
proper string height for evo's newbieguitarmaker Pickups & wiring 6 01-08-2007 04:59 PM
Evo's in Through neck Mr. S Pickups & wiring 1 11-21-2006 01:54 AM
Are Evo's Over-rated ? Jaden Polls 59 05-25-2006 06:17 PM
Evos in S series? lloop9 Pickups & wiring 0 02-01-2005 09:12 AM
Evo's and HS-2 wiring help. No coil tap. ericthelight Pickups & wiring 0 06-09-2003 10:00 PM
