Old 11-12-2006, 09:56 PM
MCR  is offline
Posts: 45  -  iTrader: (0)
Flight Case for My Jem?
Guys -
I've read the various ins and outs of flying with a guitar on the site and I've decided that I'm going to buy a flight case for my jem then attempt to put it in a gig bag and carry it on. I'm planning on taking it on my thanksgiving trip north so I can jam with my brother - something we haven't been able to do in 5 years. Its a straight flight - so I'm not worried about it being lost but I'm of course paranoid about damage.
From my reading it seems to be a matter of luck if you can stow it as a carry on - and from what US AIR has on their site I'm way over the 45 inch total size allowed. I figure it will be crazy busy too - and the coat area will be stuffed with all sorts of people's things.
So I figure a flight case is safest. But which one to get? I've looked around the net but would like info from any other jem owners about what brands are good.
Also - I know if I carry it on there is no need to loosen the strings, but if you check it as baggage should it be loosened up?
Thanks!
Old 11-12-2006, 10:07 PM
ibanezdiehard  is offline
Posts: 764  -  iTrader: (1)
Re: Flight Case for My Jem?
dude
1. i very much doubt you can take a guitar as carry on luggage
and
2. why would you put a guitar case in a gig bag?
Old 11-12-2006, 10:27 PM
surfdog777  is offline
Posts: 573  -  iTrader: (4)
If it won't fit in the overhead, you can forget about carry-on.
I see you're in Spartanburg, if you're flying out of ATL I'd definitely be worried about the baggage transfer.
If you're planning on flying over the holidays, the BUSIEST time of the year to fly, I wouldn't trust a Jem to the baggage employees. I hear stories all the time about 4-6-8 hour baggage delays, lost bags, damaged and destroyed bags......dude, send the guitar ahead of you by Fed-X insured and save yourself a TON of potential problems. Think about it.
Old 11-13-2006, 12:08 AM
MCR  is offline
I thought about sending it up, but around this time of year shippers are busy too. Plus - its a direct flight from Charlotte - which although bad isn't as bad as Atlanta. I'm figuring their is no way they can loose a bag on direct flight....
Also - I'm thinking of buying a flight case and checking it as regular baggage. I may try to carry it on - but won't be planning on it. From what I've read flight cases are super tough and have different latches then a regular case.
Old 11-13-2006, 12:10 AM
MCR  is offline
Originally Posted by IBANEZDIEHARD View Post
dude
and
Sorry - didn't mean to say I was taking a cased guitar in a bag - rather I thought of using just a gig bag and carrying it on - but as you've said and I believe - its not going to happen.
I'm looking for advice on good flight cases. Does anyone have one or know of a good one?
Old 11-13-2006, 12:28 AM
jemplayer55  is offline
Posts: 2,627  -  iTrader: (0)
Check with the airline..... you may be able to buy a seat for the guitar depending on size of the plane. Otherwise, buy a good ATA approved, lockable, flight case. Get some fragile stickers but do not mark it as an insturment. Check it as baggage, but check on additional insurance also. I would recommend an Anvil case, maybe 3/8 ply.... otherwise 1/4" will do and is cheaper. Oh yeah..... get out you wallet, good flight cases are not cheap.
http://www.anvilcase.com/applications/music.html
Old 11-13-2006, 12:31 AM
Originally Posted by MCR View Post
......... I'm figuring their is no way they can loose a bag on direct flight....
I wouldn't bet on that one, bro.....I know a dude that lost a Gibson Dove acoustic on a direct flight from Atlanta to Nashville.....believe me it can happen. Suitbags, regular suitcases are one thing, but a guitar case that's just screaming "Pawn shop money", is something else entirely. Not all baggage handlers are trustworthy & honest.
http://www.rockhardcases.com/guitar.htm
Old 11-13-2006, 12:36 AM
Rich  is offline
Posts: 19,350  -  iTrader: (21)
Flight cases are made to withstand the daily beating of road crews for decades of service. You're taking 2 plane trips, you're not dragging it behind a truck for 1000 miles. A regular Ibanez UV1000 case is plenty sufficient. Of course insure, especially against loss.
Old 11-13-2006, 01:05 AM
David McCarroll  is offline
Posts: 2,049  -  iTrader: (5)
the other route, which may be safer still assuming you are comfortable with tinkering with your guitar is to simply unscrew the neck from the body and carry the two much smaller bits on in your hand luggage!
Old 11-13-2006, 01:15 AM
^^^^ Security may mistake it for a weapon.....
Old 11-13-2006, 05:32 AM
chlamy  is offline
Posts: 283  -  iTrader: (0)
I second that. I used UV1000s to fly back and forth between France and California as checked baggage, and everything worked out as a charm. In my case, as it was "oversized" bagage, it was also handled manually by guys and didn't go through the normal check-in. The cases haven't even been scratched or dinged in the process ... be sure though to really secure your guitar in the case, as UV1000 seem to be a little large for JEms, so that the guitar doesn't bang around inside the case. i used plenty of underwear, socks and T-Shirst to block it
Old 11-13-2006, 10:50 AM
Ahhhh..... the old underwear, socks, and tee shirt padding trick. Be sure to pack extra in a carry-on though, just in case your guitar gets "delayed" or you'll be short some other things as well.
Old 11-13-2006, 11:46 AM
JJEMMER777  is offline
Posts: 8,374  -  iTrader: (5)
I've never had a problem carrying on my guitars. Even on international flights. Just nicely ask the lady at the ticket counter. Tell them it's a very expensive guitar and you donlt want it down in the cargo hold. If for some reason they will not let you, then ask if it can be stowed with the flight attendants gear. From my experiences, they won't have a problem with it. Of course it may vary by airline.
Give it a shot
Old 11-13-2006, 11:52 AM
Give it a shot
That does work..... but it's very dependant on the plane size too. Don't try it on a puddle jumper. And, have you ever seen how they load those???? Scary..... Of course you're other choice is to just drive!
Old 11-13-2006, 12:00 PM
I tend to stray clear of *puddle jumpers*
and yes....driving is always an option
electric guitar
F/S Ibanez jem 77BRMR INC hard case dannypuk Classified Ads: Ibanez JEM/UV Guitars 8 11-18-2006 06:14 PM
Jem 7bsb For Sale Inc Case dannypuk Classified Ads: Ibanez JEM/UV Guitars 11 04-11-2006 07:35 AM
JEM 10th Case Mystery Solved! - Would you believe?? Rich Archived Topics and Common Questions - GO HERE FIRST 55 06-24-2003 08:05 PM
Jem 10 Case Question jem10 JEM and Universe Guitars 6 04-26-2003 10:08 AM
Good case for my Jem??? junebughunter Gear and Equipment 2 04-16-2003 04:35 AM
