Old 01-22-2008, 06:06 PM
For_The_Love_Of_Jems  is offline
Posts: 624  -  iTrader: (57)
Unhappy
Help! Someone Painted my JEM Pickups!
I have very early jem77RB that came with an original set of Pink PAF Pro's. However, the knucklehead before me painted them BLACK!!!
Does anyone have any experience removing paint from pickups?
I would rather leave them as-is then destroy them, so proven cleanup techniques only please!!!
Thanks in advance.....
Old 01-22-2008, 06:14 PM
Jemplyr77  is offline
Posts: 162  -  iTrader: (1)
Wink
Re: Help! Someone Painted my JEM Pickups!
Mineral spirits or Naptha solvent if it is oil based, or just replace them.
Old 01-22-2008, 06:46 PM
waylay00  is offline
Posts: 3,763  -  iTrader: (10)
I would try to get the paint off first. More than likely, the coils on the pickups will have begin to "leak" as they say, which is one of the reasons older guitars sometimes sound better.
Plus, you're not out of a needless $120.
Old 01-22-2008, 07:08 PM
reguv760  is offline
Posts: 1,197  -  iTrader: (23)
Images: 5
Reviews: 12
how was it painted? if it's a plain black marker/sharpie, rubbing alcohol + elbow grease. If it's some sort of spray paint, maybe a can of graffiti remover could do the trick?
Reg
Old 01-22-2008, 07:17 PM
jb4674  is offline
Posts: 4,010  -  iTrader: (0)
Reviews: 6
Depending upon the kind of paint, you could always try dipping a qtip on paint thinner to get the paint off. With any method, make sure to cover the body of the guitar so nothing accidentally hits the finish. Post pictures of the operation.
Jimmy
Old 01-22-2008, 08:09 PM
Distantshore  is offline
Posts: 3,671  -  iTrader: (0)
Images: 4
I've used Acetone with success to remove paint from a plastic pickguard. I would test the single coil cover first, since that is the easiest to replace if damaged.
Old 01-22-2008, 09:02 PM
Fender868  is offline
Posts: 536  -  iTrader: (3)
Reviews: 6
Check this auction from 3 bay. 120213663210
The owner said his pick-ups were painted black. Don't know what his method was, but it seems to have worked fine.
Old 01-22-2008, 09:09 PM
Canadian Mark  is offline
Posts: 435  -  iTrader: (1)
I think that's some pretty good advice. I would imagine that some harsher solvents might soften or damage the plastic components if you're not careful.
Just keep in mind the organic chemistry addage 'Like dissolves like'. If the paint is water based, use water. If it is permanent, it is a non-polar compound that will probably require and organic solvent or mineral spirits.
I would personally start with water first (it is the least likely to damage and you may get lucky and the paint will be water based).
Old 01-22-2008, 09:28 PM
JJEMMER777  is offline
Posts: 8,374  -  iTrader: (5)
If you want them pink you'll probably just have to repaint them pink. I doub't you'll be able to get the black paint off (especially with "said" chemicals) and still have it look half decent
Old 01-22-2008, 09:38 PM
rickcard71  is offline
Posts: 1,803  -  iTrader: (1)
Just order new pink pups, but they won't say DiMarzio on them.
Old 01-22-2008, 10:13 PM
shotgunlew  is offline
Posts: 80  -  iTrader: (0)
Maybe goo gone.... Ive had sucess with goo-gone removing some paint drips on my tile floor...hope this helps.
Old 01-22-2008, 10:33 PM
LuredMaul  is offline
Posts: 764  -  iTrader: (22)
I have used Mineral Spirits and other than it melting the glue on the ribbon wrapping your coils it's perfectly fine for the bobbin tops .wipe it on scrub of the paint and rinse it off with a rags and windex.
Old 01-23-2008, 03:42 AM
jono  is online
Posts: 5,004  -  iTrader: (2)
My vote is for new pickups, as Waylay said it's $120 (it'd be twice that over here in the UK ) And for that you can tailor the sound and look of the guitar to your liking. If you want the original look, order some pink pickups, if you want to try something else, like cream/black zebra coils, now's your chance.
It'll be much easier to clean the original pickups once they're removed from the guitar anyway
Old 01-23-2008, 10:52 AM
Thumbs up
Wow!!! Thanks for all the suggestions. I will be trying some out over the weekend, and will let you know the results.
I am going to try and clean these up. I really like the tone from the older 87 PAF Pro's. But, I will buy new ones if all else fails.
Old 01-23-2008, 11:04 AM
syxxstring  is offline
Posts: 156  -  iTrader: (1)
I would start as mild as possible with solvents and work my way to the harsher stuff.
Start with rubbing alcohol and work your way to lacquer thinner. See if maybe gently heating the pups with a hair dryer on low will allow you to scrape it off.
What kind of plastic does Dimarzio use? Is it a nylon that is dyeable or is it a solvent resistant type?
paf pro, pickup cover
Dimarzio pickups for JEM 7V WH (gold) BK1 Pickups & wiring 6 08-22-2007 10:18 PM
Next Jem to buy after a Jem 10th? hamand JEM and Universe Guitars 35 03-18-2007 11:01 PM
WTB Set Of Jem Pickups clar-v-d Classified Ads: Ibanez JEM/UV Guitars 2 01-24-2005 08:05 AM
Jem 555 replacement model......... - I found it in Hong Kong cowcowcow JEM and Universe Guitars 18 04-17-2002 06:02 AM
Favorite JEM pickups? Tigerstripe JEM and Universe Guitars 10 03-09-2002 01:03 PM
