Old 01-11-2001, 08:33 AM
edo  is offline
Posts: 49  -  iTrader: (0)
How do you measure a scale length ?
I think that this is a stupid question, but hey I'll still ask it to you, guys...
I've got two guitars sitting in front of my face right now. *One is a Fender '57 and the other is an Ibanez PGM300 and while both guitars was stated to have a 25.5 scale but when I'm trying to measure the scale, it comes out differently. *
How do you measure a scale length ( From ... to ... ) :
a. On a guitar with locking nut ( Floyd Rose Tremolo )
b. On a guitar with vintage tremolo
c. On a guitar with stop tail/tune-o-matic bridge
Regards,
Edo
Old 01-11-2001, 10:22 AM
darren wilson  is offline
Posts: 4,190  -  iTrader: (0)
Good question!
Because of the variable position of the bridge saddles to achieve correct intonation, measuring the full length of the string will invariably give you different measurements for each string.
In my estimation, the best way to measure a guitar's scale length is to measure from the nut (right where the string breaks over the edge of the fretboard) to the middle of the crown of the 12th fret, then multiply by 2.
Old 01-11-2001, 11:29 AM
iain  is offline
Posts: 367  -  iTrader: (0)
The only scale I know of is the pentatonic, and that is 5 long
Old 01-11-2001, 03:06 PM
ellsobrien  is offline
Posts: 80  -  iTrader: (0)
D'Adarrio has a good page on figuring out the scale for bass gtrs. I guess it would be the same for a gtr.
Check it out.
http://www.daddario.com/guitartips/dawbbass.htm
Hope this helps.
Old 01-11-2001, 03:35 PM
Jimi D  is offline
Posts: 737  -  iTrader: (0)
here's something for the Things That Make You Go Hmmmmm... I read an interesting article in an old (like 1996) issue of Guitar Techniques (Brit mag) that had the author measuring "actual" scale length on a number of guitars and comparing it to the manufacturer's declared specs. It was amazing that a> most of the specs were inaccurate, and b> many of them were off by A LOT! I mean, you can feel the difference between a Les Paul's 24.75" scale length and the 25.5" scale length of a Strat, and some of these differentiations from spec were well over .5"! I'd think you could feel the difference between the declared and actual scale lengths...
Old 01-11-2001, 04:22 PM
jay ratkowski  is offline
Posts: 2,273  -  iTrader: (7)
Reviews: 3
The way the Fender and Ibanez machines pump out guitars... chances are the scale lengths remain constant... but more likely than not, they just round the number off for simplicity. *At least, that's my guess...
Old 02-02-2012, 02:14 AM
Jemini920  is offline
Posts: 12  -  iTrader: (0)
Re: How do you measure a scale length ?
The Ibanez Jem 7v is a 25.5" scale length
Old 02-02-2012, 06:53 AM
Zoot  is offline
Posts: 879  -  iTrader: (23)
Images: 98
I always thought it was the length from the bottom of the nut above the first fret to where the string actually sits on the saddle of whatever bridge it is . And having just measured my 7v that is correct for that guitar.
Old 02-02-2012, 09:35 AM
Takin' a Ride  is offline
Posts: 1,760  -  iTrader: (27)
Measure from the saddle to the nut. The scale length isn't a set number and there will be variations based on saddle position, but all the numbers will either be close to 25.5" or 24.75".
Old 02-02-2012, 02:54 PM
djohns74  is offline
Posts: 580  -  iTrader: (0)
The only thing scale length really determines is the spacing between the frets, everything else is a matter of intonation. If two guitars have a 12th fret that is 12.75 inches from the nut, they are both 25.5" scale guitars, no matter where their bridges or saddles end up. Even if the saddles somehow wound up closer to 24.75" from the nut, as long as the frets are spaced for 25.5", it's still a 25.5" guitar, just probably one with terrible intonation.
Old 02-02-2012, 05:28 PM
Hikey Mikey  is offline
Posts: 1,394  -  iTrader: (0)
Wow, eleven years, it blows my mind that the internet, much less Jemsite, has even been around that long.
Peace
Mike
Old 02-02-2012, 09:07 PM
Ekim  is offline
Posts: 1,483  -  iTrader: (1)
Reviews: 4
Funny, Mike.
I've been surfing the net since 1994, gratis of the US Federal Govt. Wasting YOUR tax dollars for over 20 years now...
Old 02-02-2012, 10:01 PM
Jem7v scale length is 25.5" which is 25 and a half in inches from nut to saddle.. some ppl get confused with scale length as fretboard length
Old 02-03-2012, 02:37 PM
The Euphor  is offline
Posts: 2,948  -  iTrader: (4)
You are right about that. I wonder if you're a bit confused too, as scale length indicates the length of the fretboard as well. The ringing part of the string is the total length, and it is - as Djohns74 said above - a result of the spacing between each fret. Resulting in a different scale.
11 year bump is nothing! At least the thread finally got answered properly. Back then nobody knew!
bridge saddles, floyd rose, floyd rose trem, floyd rose tremolo, guitar tech, ibanez pgm, les paul, locking nut, matic bridge, scale lengths, vintage trem
