How do you measure a scale length ? - Page 2 - Jemsite
post #16 of 19 (permalink) Old 03-16-2013, 11:39 AM
dex
Re: How do you measure a scale length ?
Can't believe this is confusing as many people as it is.
As Darren Wilson posted back in 2001, measure the distance from the edge of the nut (or zero fret if your guitar has a zero fret) to the 12th fret and double the distance.
clintham, not sure where you read this as stewmack site says the same thing.
WHAT IS SCALE LENGTH?
A guitar's scale length is calculated by measuring the distance from the front edge of the nut, where it butts against the end of the fingerboard, to the center of the 12th (octave) fret, then doubling that measurement.
http://www.stewmac.com/freeinfo/Fret...alelength.html
dex is offline
post #17 of 19 (permalink) Old 03-16-2013, 11:46 AM
dex
clintham, if you are building a guitar and are not sure where to place the bridge, place it so the edge of a saddle is the same distance to the 12th fret as the edge of the nut is.
Make sure your saddle is centred so you get as much adjustment travel each way as otherwise you may not be able to intonate some of the strings later.
I hope that makes sense.
dex is offline
post #18 of 19 (permalink) Old 03-16-2013, 08:16 PM
Doing this has always worked out for me, never had intonation problems installing a bridge like this
Swirltop is offline
post #19 of 19 (permalink) Old 03-24-2013, 07:09 PM
thanks that very helpful
clintham is offline
bridge saddles , floyd rose , floyd rose trem , floyd rose tremolo , guitar tech , ibanez pgm , les paul , locking nut , matic bridge , scale lengths , vintage trem
Human Verification
RG6-CDS2 XL scale length davidwinston10 Other Ibanez Guitars (including Premiums) 8 07-03-2009 08:17 AM
Actual scale length? measure from nut to centre of studs? MorbidAngel Tech: Setup, Repairs and Mods 1 12-28-2003 07:40 PM
Ibanez AF 207 7 string jazzer-24.7"scale?? - Scale length is speedball Comments to Ibanez 12 01-12-2003 09:44 PM
How do you like the XL scale length? Zeek Other 7+ string Guitars 22 11-13-2002 11:02 AM
How to measure the scale length of a guitar? eg Tech: Setup, Repairs and Mods 3 09-23-2002 11:33 PM
HTML code is On
