How do you measure a scale length ? - Jemsite
post #1 of 19 (permalink) Old 01-11-2001, 07:33 AM Thread Starter
edo
I think that this is a stupid question, but hey I'll still ask it to you, guys...
I've got two guitars sitting in front of my face right now. *One is a Fender '57 and the other is an Ibanez PGM300 and while both guitars was stated to have a 25.5 scale but when I'm trying to measure the scale, it comes out differently. *
How do you measure a scale length ( From ... to ... ) :
a. On a guitar with locking nut ( Floyd Rose Tremolo )
b. On a guitar with vintage tremolo
c. On a guitar with stop tail/tune-o-matic bridge
Regards,
Edo
edo is offline
post #2 of 19 (permalink) Old 01-11-2001, 09:22 AM
Good question!
Because of the variable position of the bridge saddles to achieve correct intonation, measuring the full length of the string will invariably give you different measurements for each string.
In my estimation, the best way to measure a guitar's scale length is to measure from the nut (right where the string breaks over the edge of the fretboard) to the middle of the crown of the 12th fret, then multiply by 2.
darren wilson is offline
post #3 of 19 (permalink) Old 01-11-2001, 10:29 AM
The only scale I know of is the pentatonic, and that is 5 long
iain is offline
post #4 of 19 (permalink) Old 01-11-2001, 02:06 PM
D'Adarrio has a good page on figuring out the scale for bass gtrs. I guess it would be the same for a gtr.
Check it out.
http://www.daddario.com/guitartips/dawbbass.htm
Hope this helps.
ellsobrien is offline
post #5 of 19 (permalink) Old 01-11-2001, 02:35 PM
here's something for the Things That Make You Go Hmmmmm... I read an interesting article in an old (like 1996) issue of Guitar Techniques (Brit mag) that had the author measuring "actual" scale length on a number of guitars and comparing it to the manufacturer's declared specs. It was amazing that a> most of the specs were inaccurate, and b> many of them were off by A LOT! I mean, you can feel the difference between a Les Paul's 24.75" scale length and the 25.5" scale length of a Strat, and some of these differentiations from spec were well over .5"! I'd think you could feel the difference between the declared and actual scale lengths...
Jimi D is offline
post #6 of 19 (permalink) Old 01-11-2001, 03:22 PM
Reviews: 3
The way the Fender and Ibanez machines pump out guitars... chances are the scale lengths remain constant... but more likely than not, they just round the number off for simplicity. *At least, that's my guess...
jay ratkowski is offline
post #7 of 19 (permalink) Old 02-02-2012, 01:14 AM
Re: How do you measure a scale length ?
The Ibanez Jem 7v is a 25.5" scale length
Jemini920 is offline
post #8 of 19 (permalink) Old 02-02-2012, 05:53 AM
I always thought it was the length from the bottom of the nut above the first fret to where the string actually sits on the saddle of whatever bridge it is . And having just measured my 7v that is correct for that guitar.
Zoot is offline
post #9 of 19 (permalink) Old 02-02-2012, 08:35 AM
Measure from the saddle to the nut. The scale length isn't a set number and there will be variations based on saddle position, but all the numbers will either be close to 25.5" or 24.75".
Takin' a Ride is offline
post #10 of 19 (permalink) Old 02-02-2012, 01:54 PM
The only thing scale length really determines is the spacing between the frets, everything else is a matter of intonation. If two guitars have a 12th fret that is 12.75 inches from the nut, they are both 25.5" scale guitars, no matter where their bridges or saddles end up. Even if the saddles somehow wound up closer to 24.75" from the nut, as long as the frets are spaced for 25.5", it's still a 25.5" guitar, just probably one with terrible intonation.
djohns74 is offline
post #11 of 19 (permalink) Old 02-02-2012, 04:28 PM
Wow, eleven years, it blows my mind that the internet, much less Jemsite, has even been around that long.
Peace
Mike
Hikey Mikey is offline
post #12 of 19 (permalink) Old 02-02-2012, 08:07 PM
Reviews: 4
Funny, Mike.
I've been surfing the net since 1994, gratis of the US Federal Govt. Wasting YOUR tax dollars for over 20 years now...
Ekim is offline
post #13 of 19 (permalink) Old 02-02-2012, 09:01 PM
Jem7v scale length is 25.5" which is 25 and a half in inches from nut to saddle.. some ppl get confused with scale length as fretboard length
post #14 of 19 (permalink) Old 02-03-2012, 01:37 PM
You are right about that. I wonder if you're a bit confused too, as scale length indicates the length of the fretboard as well. The ringing part of the string is the total length, and it is - as Djohns74 said above - a result of the spacing between each fret. Resulting in a different scale.
11 year bump is nothing! At least the thread finally got answered properly. Back then nobody knew!
The Euphor is offline
post #15 of 19 (permalink) Old 03-15-2013, 09:24 PM
another bump for this thread - the stewmac calculator says different. im a little confused now
"Bridge placement for 25.5 mm scale:
Distance from the fretboard edge of the nut to center of forward-most mounting screw or pivot post"
this suggests its measured from the centre of the trem mount :s
help!
clintham is offline
bridge saddles , floyd rose , floyd rose trem , floyd rose tremolo , guitar tech , ibanez pgm , les paul , locking nut , matic bridge , scale lengths , vintage trem
Human Verification
RG6-CDS2 XL scale length davidwinston10 Other Ibanez Guitars (including Premiums) 8 07-03-2009 08:17 AM
Actual scale length? measure from nut to centre of studs? MorbidAngel Tech: Setup, Repairs and Mods 1 12-28-2003 07:40 PM
Ibanez AF 207 7 string jazzer-24.7"scale?? - Scale length is speedball Comments to Ibanez 12 01-12-2003 09:44 PM
How do you like the XL scale length? Zeek Other 7-string Guitars 22 11-13-2002 11:02 AM
How to measure the scale length of a guitar? eg Tech: Setup, Repairs and Mods 3 09-23-2002 11:33 PM
