Old 04-12-2005, 07:25 PM
bluealien  is offline
Posts: 959  -  iTrader: (0)
Question
How to tell a Jem 7vwh body from a Jem555wh body?
I was looking up some specs and noticed that the Jem 7vwh body is made of Alder with a super thin 0.5mm basswood veneer on the top and back, and the Jem 555wh is just made out of Basswood?
Are there any visible signs or marking to tell the difference or just look at the unpainted neck cavity to tell the wood difference. how do you tell the difference of the wood?
thanks for any help.
Old 04-12-2005, 10:37 PM
parker_fly  is offline
Posts: 398  -  iTrader: (6)
Re: How to tell a Jem 7vwh body from a Jem555wh body?
You should be able to tell if they are side by side by the trem cavities. The Jem 7vwh will be larger than the 555's.. Other than that im not sure.
Old 04-12-2005, 11:45 PM
gash  is offline
Posts: 79  -  iTrader: (0)
i thought there was a stamp or mark in the neck pocket.
Old 04-13-2005, 12:10 AM
moro  is offline
Posts: 623  -  iTrader: (2)
Alder has a reddish tint while basswood is white. See here:
http://www.warmoth.com/guitar/option..._bodywoods.cfm
Also, here are some pics of my Kramer, which people tell me is made of alder:
http://www.jemsite.com/forums/showthread.php?t=35113
Old 04-13-2005, 08:05 AM
whatshisname  is offline
Posts: 882  -  iTrader: (0)
The AANJ on the 555 isn't as pronounced, either. Take a look here- http://www.jemsite.com/axes/htm_features/neckjoint.htm
Old 04-13-2005, 08:16 AM
marianozz  is offline
Posts: 2,221  -  iTrader: (20)
Also, if you can a/b them on the spot, the 7's body should be heavier...
Old 04-13-2005, 10:52 AM
RCB  is offline
Posts: 1,598  -  iTrader: (1)
The 7VWH probably doesnt have the veneer in the neck pocket or the trem cavity, so the visible parts of wood on a 7vwh will be alder and the visible parts of wood in the 555 should be basswood.
Old 04-13-2005, 10:56 AM
jemsite  is offline
Administrator
Posts: 9,271  -  iTrader: (5)
Images: 11
it should be obvious by the color also, the VWH is much more vibrant white... glen
Old 04-13-2005, 03:41 PM
Jem7RB MK  is offline
Posts: 2,341  -  iTrader: (20)
Neck pocket stamp ! probably the best give away !!
Does the 555 still have the angled trem routes ala trs systems ? that would be another give away, but the stamp wins it i reckon
Rob
ibanez rg 1570 or jem 7vwh guitario JEM and Universe Guitars 4 03-01-2004 06:46 PM
Wood choice for JEM - Before I order that custom body Jeroenn JEM and Universe Guitars 13 06-08-2001 01:14 PM
Jem 7VWH mods TonyUK JEM and Universe Guitars 17 05-09-2001 03:47 PM
