Re: Humidifying for winter
20% is way too low for acoustics! Even 30% is too low. I'm pretty sure they should be at 40% to be "comfortable".
For acoustics, setups are the least of your worries; checking, cracking, etc. all can happen from low humidity. There's lots of unfinished wood exposed. Scream's house humidifier is a good idea if you can do that (it's healthier for people, too) or a room humidifier and a hygrometer to keep tabs on the level.
In the dead of January when nights can hit single digits, those little tabletop guys won't keep a room at 40%, so unless you can get a bigger one you may want to buy or make humidors for your acoustics and keep them in cases. This can work well, especially with plastic hardshell cases (that let little moisture escape) .
