identifying year of Edge?
10-02-2007, 09:11 AM
Devon8822
Posts: 389 - iTrader: (
I'm wondering if there is anyway to identify what year an edge or edge lo-pro is from? Is there even anything to distinguise reissues from origionals? thanks
Devon8822
Find all posts by Devon8822
10-02-2007, 11:42 AM
jb4674
Posts: 4,010 - iTrader: (
Reviews: 6
Re: identifying year of Edge?
I don't think there would be a way, since the trems are not stamped with a serial number that I know of. I could be mistaken though... Rich might be able to have a better answer.
Jimmy
jb4674
Find all posts by jb4674
10-02-2007, 01:02 PM
bringer of torture
Posts: 250 - iTrader: (
When did Ibanez stop putting the palmguard (or whatever it is) on the JEMs? I always thought that it added a unique look to those old 777s...
bringer of torture
Visit bringer of torture's homepage!
Find all posts by bringer of torture
10-02-2007, 01:20 PM
Rodney James
Posts: 2,295 - iTrader: (
03:39 AM
Rodney James
Find all posts by Rodney James
10-02-2007, 01:37 PM
nuno
Posts: 4,725 - iTrader: (
there are a few details that can't detect the exact incept date but pretty much the period, early '86/'87, the '90s and so on.
for example, the first Edges in '86/'87 had a different spring block, it was thinner but wider and taller, it was called S or HS. see pic:
it also had the arm insert with a longer threat, vs the '90s Edge where the threat was cut shorter:
early Edge arm insert:
(yeah, it's a Lo-Pro but no matter)
'90 Edge arm insert
also, the early Edge had no Stud-Locks. hope that helps
nuno
Visit nuno's homepage!
Find all posts by nuno
10-02-2007, 01:52 PM
Devon8822
Some good info, what I want to find out is if, some bridges i have my eye on, are reissues from the late ninties or later or if there are from the early 90s. I'm restoring the bridge on a jem so im looking for a 90' one.
Devon8822
10-02-2007, 02:39 PM
projectjem
Posts: 664 - iTrader: (
hmmmm good question i would guess late 40's
projectjem
Find all posts by projectjem
10-02-2007, 02:44 PM
andy7jem
Posts: 6,504 - iTrader: (
I had to think about that for a minute
It's been a long day
andy7jem
Find all posts by andy7jem
10-02-2007, 05:15 PM
Reinder
Posts: 138 - iTrader: (
Yeah I was thinking ,,A
Les Paul
doesn't have a trem, what's that about?'' But then I got it...
Reinder
Find all posts by Reinder
10-03-2007, 05:52 AM
nuno
Devon8822
i think the only "reissue" of the Edge has been made for the RG 20th. other than that, an Edge is just an Edge. the only detail i'd be aware of is the taller spring block from early '86/'87, which would stick out of the trem cavity.
nuno
10-03-2007, 06:03 AM
nuno
another couple of details that just came to mind: the early Edges were molded smoother, the saddles edges were rounder, smoother. since around mid '90s they were molded squarer and tighter. also, early Edges didn't have the Fine Tuners lock plastic rings.
nuno
10-03-2007, 09:40 AM
Rodney James
03:39 AM
Rodney James
10-03-2007, 09:52 AM
Devon8822
Pirvey Chinnfield
Actually the edge took a change from the early years to mid 90's somewhere. We compared a 1998 RG550DY to 1987 88 & 89 Jems, and the 98 trem is different,
base plate
and spring plate.
So what exactly is the difference between the baseplate and spring plate over the older and earlier models?
Devon8822
10-04-2007, 04:23 AM
Sunrise
Posts: 114 - iTrader: (
I'm not sure of the exact difference but I don't think it will be a difference that would affect its performance/originality in a 90's Jem anymore than not using every original screw that was supplied.
Sunrise
Find all posts by Sunrise
10-04-2007, 09:51 AM
Rodney James
03:39 AM
Rodney James
arm holder
base plate
edge trem
edge trems
les paul
how to tell what year a guitar was made
what year did gibson start to chamber
is my edge trem bar in all the way
edge pro to lo pro
rya
05-11-2011
03:54 AM
edge 3 to lo pro edge
hoockey
05:15 AM
Can I use Edge posts with an Edge Pro??
PatrickSimsCustomShopUSA
Tech: Setup, Repairs and Mods
11:00 AM
String spacing of Edge/Lo-Pro vs Edge Pro
MetalZone
08:59 AM
Edge III Mystery... Solved?
eclecticmage
47
10-22-2006
01:08 PM
01:01 PM
