Jem 777 fretboard separation from neck
You'll need some good wood glue, a clamp, wet paper towel, clear mylar like a report cover, and a spreader (I have a small wedge that's sorta like a pencil but with a tip as wide as it is around). *Spread the board from the neck enough to allow you to get glue in there. Cut the mylar into a strip. I'll lay glue all down the seperation and then on the mylar, work the glue into the gap as deep and far as you can using the mylar (if you use paper it'll just act like wet paper, it needs to be stiff and why I use the mylar). When you get the glue dispersed clamp the board down, but not TOO tight, you don't want to squeeze all the glue out!! Just clamp it down till it visually looks together, no further. Cleanup all the glue that came out with the wet towel and let it sit overnight. Problem solved, and a very easy fix, I'd rate it a 1 hammer on the toughness scale :biggrin:
