Old 11-15-2006, 07:43 AM
Batchimp RG  is offline
Posts: 2,378  -  iTrader: (2)
JEM 77DY TREM ISSUE
Jempeople,
My trem arm on my Edge is annoying me, it keeps coming loose. When I use it feels unstable. I recently opened up the back cover and tightened the screw and that solved the problem for a few days but the looseness is back.
Do I have to keep tightening the damned thing?
Thanks
Old 11-15-2006, 08:15 AM
crevis  is offline
Posts: 2,599  -  iTrader: (1)
Re: JEM 77DY TREM ISSUE
You need to replace the bushs around the arm evey now and again, and make sure the holder is screwed in properly. Find something that will fit in the slots on the front of it.
Old 11-15-2006, 08:30 AM
I'll have another look at it again tonight and either post or PM you mate.
When you say "bushs" are those the plastic rings around the actual base of the arm?
Old 11-15-2006, 08:42 AM
crevis  is offline
yeah, they wear out after a while. you have to get your dealer to order them.
Old 11-15-2006, 08:52 AM
GilkyBear  is offline
Posts: 4,110  -  iTrader: (16)
Another fix is to put a little nail polish on the arm under where the bushings go, then put them back on after it dries. That will give them enough extra push to be snug. Experiment a little as necessary to get the right amout on there. Some people have put a little duct tape on there under the bushings too.
Old 11-15-2006, 08:57 AM
markg5150  is offline
Posts: 2,361  -  iTrader: (2)
Bits of D'addario string bags to pad the arm out slightly works well also.
Old 11-15-2006, 09:03 AM
Good tip. I know there is a thing used by dentists, a little metal ring that is perfect for the job, but I can't remember what it is called. A little research (google) would probably provide the answer.
Old 11-15-2006, 09:05 AM
crevis  is offline
great suggestions. i can never get the bushes off without breaking them tho so i have to get new ones if i want to take them off.
Old 11-15-2006, 09:13 AM
Good tips folks, but I somehow suspect it not to be the bushings, it seems to be a holding screw or something under the trem that keep coming loose. I will double check this later...
Old 11-15-2006, 09:25 AM
Here's some good scoop in a previous post...
http://www.jemsite.com/forums/showth...ght=loose+trem
Old 11-15-2006, 09:29 AM
And if that doesn't work, here is the total scoop from yoda...
http://www.ibanezrules.com/tech/setup/squeaky.htm
http://www.ibanezrules.com/tech/setup/loose_holder.htm
Old 11-15-2006, 09:32 AM
nuno  is offline
Posts: 4,725  -  iTrader: (0)
if you want to get rid of the problem "virtually" forever, try these tricks:
put not one, but two hex nuts to lock the arm-holder on the baseplate, and use Loktite (don't know how you call that glue that tightens the screws):
[continues in the post below...]
nuno  is offline
while you're at it, glue the arm-retainer spring screw also:
Old 11-15-2006, 09:33 AM
nuno  is offline
then put a nice dab of silicone either on the hex nuts and on the arm-retainer screw.
i know it looks nasty, but it does work great and... who will ever see it? you can even smooth it out to make it look better, but it will be trickier to peel off, if ever needed. the silicone blocks the nuts and screws from vibrations, but it's super easy to peel off when needed, and it won't leave dirt or whatever. it works great and costs almost nothing.
Old 11-15-2006, 09:59 AM
Crikey...that's alot more serious than I was expecting. But I think you are right, nuno. That nut, as seen in your pics, refuses to stay tight so I guess I have to Loktite it...
trem arm
3120 Jem Hybrid - Trem Problem. Maiu Tech: Setup, Repairs and Mods 10 03-27-2006 09:17 PM
setting the trem angle...questions atarilovesyou Tech: Setup, Repairs and Mods 2 03-07-2006 04:39 AM
jem 77DY - is this a good deal? your opinon. aussie stu JEM and Universe Guitars 7 06-28-2002 12:43 AM
Repairing trem knife edges - Trem on my JS1000 will not retu Jason Stone Archived Topics and Common Questions - GO HERE FIRST 2 01-01-2001 09:24 PM
