Old 09-04-2009, 01:23 PM
Jesus jem  is offline
Posts: 24  -  iTrader: (0)
Jem 77v open e string buzzing help
Hey guys i just bought a jem 77v. And i lowerd the action a little bit and all the strings are fine no buzzing on any frets except for the low e string. it buzzes when i play from the 1st fret to the 13th fret.. but its minor buzzinng and you can only tell when i play clean stuff. Also it buzzes on open notes What can i do to fix this besides bring it in to guitarcenter and have them screw it up and charge me alot?
Old 09-04-2009, 01:41 PM
Timbaline  is offline
Posts: 508  -  iTrader: (0)
Reviews: 7
Re: Jem 77v open e string buzzing help
Loosen your truss rod just a bit.
Old 09-04-2009, 06:42 PM
lynchfan6  is offline
Posts: 194  -  iTrader: (0)
+1 My 7Vwh used to do the same thing....it's all a combination of truss rod and bridge height, and you can't often get away with just tinkering with one when you are fine tuning your action. By the way, I just added a new 77V to my collection last summer.....beautiful guitar, same neck as my 7V. I can't put these guitars down!
Old 09-05-2009, 12:10 AM
Thanks alot im going to do it tomarrow. Just got back from a gig and WOW dont want to brag but my mesa in my house sounds decent and i play louder in my house than i did at this party and the sound out doors just blew my mind. It sounded better than any rock metal recording i have ever herd. Not joking. and the jem threw it i didnt want to stop playing it was the PERFECT tone, jems are the most addicting guitar i have come in to contact with! and it will be more addicting when i get the buzzing away.
-Steven
Old 09-05-2009, 08:33 AM
vy100  is offline
Posts: 410  -  iTrader: (2)
Reviews: 3
1- You need more neck bow loosening the Truss rod as said (that eliminates buzzing from 2nd to 5th fret)
2- Rise the bridge to eliminate buzz from 7 to last fret
3- If with this settings strings are too high on the upper frets the neck may need shimming
4- To elminate the 1st fret buzzing you may need to rise the nut putting a thin half shim under the bass side
Remember that ABSOLUTE NO BUZZING requires High Nut, More Neck Bow and High bridge, which involves HIGH ACTION. You have to set that three elements to find the equilibrium at the lower action wanted. Minimun unplugged fret buzzing on the low strings in some frets (specially upper ones) that is not noticed when plugged it is fine for me.
NOTE: I have find that most Ibanez guitars have a minimum 3th fret Low E string buzzing that is very difficult to set properly. Donīt be stressed about that if it sounds good plugged on the clean channel.
NOTE 2: You can find INSTRUCTIONS to do that settings on the "tech" of this page or at Ibanez Rules. Good luck and let do it to an expert if not sure at any step.
Old 09-05-2009, 04:01 PM
Thanks alot for the help. I fixed the open buzzing but there is still buzzing going on but only noticeable on the clean channel.. But i'll deal with it.. I just have one last question. My mtm1 uses 10's strings and the action is lower than the jems and its in c tuning and sometimes in b and there is buzzing only when im not pluged in but when i plug in and play clean you cant even tell there is buzzing.. same thing on my les paul. So why is it the jem thats buzzing? (im using 9's on my jem)..My jems action is the highest of the 3 guitars but it is also the easiest/ fastest to play on and has the most noticable buzzing while pluged in playing clean.. It is only the low E string though, the strings are new and I dont see why it would be doing this. The frets on the MTM1 are higher and wider if that has anything to do with it.. the les paul is around the same height.
open string buzzing callen3615 JS (Satriani Model) Ibanez Guitars 6 05-13-2008 01:09 PM
hmm open g buzzing 6StringGod Tech: Setup, Repairs and Mods 6 12-01-2003 02:00 AM
Buzzing B String sam_at2001 Tech: Setup, Repairs and Mods 3 01-15-2003 11:13 PM
Open string buzzing eg Tech: Setup, Repairs and Mods 36 09-05-2002 03:44 AM
How do you stop open strings from buzzing? - my high e and b puppiesonacid Tech: Setup, Repairs and Mods 4 08-20-2001 01:51 AM
