Originally Posted by ANT5150
Does anyone know why the pickups on my Jem BFP have less output than my other Jems. The pickups are original and the same as my FP but are lacking the same clarity and volume. I have adjusted pickup height but still no improvement. Can pickups get old?
I agree with the other guy. Check your pots first. Might have a volume or a tone pot going bad. Pots will wear out over time, especially if you use them alot. I've experienced this on more then one guitar. Mainly my strats where I do alot of volume swells. Tends to wear the pot out and it will get a minor crackle to it over time. Which then means it's just time to change it out.
I will say though, that not all pick-ups are the same(even if they are the same brand). While it's highly unlikely, you may have ended up with pick-ups that aren't wound the same as the others.
There's a number of things it could be and the funny thing is, it could be any combination of them. My honest advice would be. If it's really bothering you that much, just rip out everything and start over. Get new Evo's or PAF's(whatever you use), install new wiring and pots and selector switch. Just do a complete flush of the system and start over.
A lot of the time it will work for you.
