JEM RG and S trem Blocks - Jemsite
post #1 of 5 (permalink) Old 05-05-2012, 10:07 AM Thread Starter
Smile JEM RG and S trem Blocks
Hello
I've got a few Ibanez trems sitting around.
Some have short blocks and some have long blocks.
Are the short blocks only for S bodies?
Can I use a short block trem in a JEM or RG, or will I need a long block?
If I need a long block, does anyone have along block they don't need from a brass block upgrade or something?
Thanks
Sebastian
sebastian is offline
post #2 of 5 (permalink) Old 05-05-2012, 12:04 PM
Re: JEM RG and S trem Blocks
I might have a long block sitting around. Can you measure both so I can compare to what I have? I have an old parts trem sitting around and I can't imagine ever using the sustain block on it for anything.
Takin' a Ride is offline
post #3 of 5 (permalink) Old 05-05-2012, 12:09 PM
I have an edge III orig block and an edge Lo-pro orig block you are welcome to (both upgraded to brass aftermarket).
kfssdude is offline
post #4 of 5 (permalink) Old 05-05-2012, 01:43 PM
You need a 32 mm brass block.
tearsx is offline
post #5 of 5 (permalink) Old 05-05-2012, 01:48 PM Thread Starter
The long block I have is 42mm long.
PM me too cover the shiping and what ever you what for the block if anything.
I'm also short one Lock Block, the part inside the saddle that pinches the string in.
Thanks
guys-
trem block ibanez
Human Verification
Big Blocks and Other Upgrades py36 Tech: Setup, Repairs and Mods 24 09-26-2011 03:02 PM
FS: Dimarzio Virtual 2, Ibanez Edge blocks, Peavey Trem t1r12003 Classified Ads: Guitars and Gear 1 07-02-2010 10:05 AM
Tremolo saddle blocks help?! sirshredsalot Tech: Setup, Repairs and Mods 2 03-17-2009 01:48 AM
measurements for wood blocks - trem blocking klopper22 Tech: Setup, Repairs and Mods 1 10-12-2008 07:51 PM
JS1000 Inlay Blocks (for pre '98) - What does it say? jippy JS (Satriani Model) Ibanez Guitars 6 08-27-2001 10:07 PM
