Re: Jem7 Works With Floyd Rose Pro? What Locking Nuts Do I Need?
The locking nut you won't need to change (I assume by locking nut you mean the locking nut, the thing on the headstock)
Otherwise, I've seen a UV7PWH that easily took a floyd rose 7, so it may just fit, as simple as that. So I'd see how well you do when you get it, if it works, it works, if it doesn't, then i've no idea other than buying and edge or a lo pro edge.
Or are you saying you haven't got the trem posts?
