Old 01-29-2005, 12:01 AM
jemoctave  is offline
Posts: 16  -  iTrader: (0)
JEM7DBK nut/bridge radius differs from neck radius ?!?!
2001 JEM7DBK, as new, all seems original parts
The radius of the neck seems to be slightly tighter than the radius of the nut & bridge.
This means the action is lower on the centre d & g strings, and higher on the E strings.
It is consistant over the whole neck.
The action is very low and the guitar is working fine except for this apparent radius difference. The difference at the nut is the E strings are approx 0.5mm higher off the frests than the D & G strings.
I urgently request advise if this is normal or not? It does seem very strange.
Thanks
Old 01-29-2005, 12:03 AM
Rich  is offline
Posts: 19,356  -  iTrader: (21)
Re: JEM7DBK nut/bridge radius differs from neck radius ?!?!
I go through about 1000 saddle shims a year, and considerring I've had to make them for the last 3 months I'm about to pull all my hair out!
Old 01-29-2005, 05:55 PM
Smile
Sorry Rich but I don't understand a word of that
Old 01-29-2005, 09:04 PM
KDAD  is offline
Posts: 25  -  iTrader: (0)
Normal...that's why Rich uses so many shims...he works on a lot of guitars and they need to be shimmed
Old 01-30-2005, 12:01 AM
Do I have to get down on my knees like Dave does to Steve when he takes a hold of Steve's lower neck and goes up and down it?
Old 01-30-2005, 01:21 AM
JESTER700  is offline
Posts: 2,234  -  iTrader: (0)
This is normal with lots of brands. The nuts & bridges only come in certain radii, and the variation in necks is much greater. My one Carvin neck is the same way, which was one reason I chose a real nut with locking tuners on my latest one.
locking tuners
JS neck stats for custom neck - JS neck stats for custom nec SilverSurferII JS (Satriani Model) Ibanez Guitars 3 03-26-2011 07:39 PM
JS900 - Is the neck Multi Radius................... Scott 74 JS (Satriani Model) Ibanez Guitars 5 08-23-2001 12:52 PM
Warmoth compond radius neck? - 10" at the nut to 16" at the gkelm Other 6-string Guitars (non-Ibanez brand) 6 05-23-2001 08:40 PM
JEM neck and JPM neck - Comparason Matt55655 JEM and Universe Guitars 11 04-24-2001 06:51 PM
My USRG10 Needs a Neck Adjustment Enigmaverick J-Custom, USA Custom & Prestige Ibanez Guitars 3 03-12-2001 11:35 PM
