Old 03-25-2005, 12:44 AM
unique77  is offline
Posts: 124  -  iTrader: (0)
Jem7vwh - claw spring range
Does anyone know how much you should turn your claw spring adjustment screws or how to know when you should stop. Im considering switching to ten gauge strings with my new jem, but i don't know when to stop or when i should add a new spring. Should i even switch to tens in the first place, give me your opinions please.
Old 03-25-2005, 12:46 AM
jemsite  is offline
Administrator
Posts: 9,271  -  iTrader: (5)
Images: 11
Re: Jem7vwh - claw spring range
you can pretty much screw the claw spring in until you run out of space and/or you start stripping the screws Switching to 10s should not be a problem... glen
Old 03-25-2005, 12:48 AM
unique77  is offline
Your talking about them stripping against the screw plate right? And what guage strings do you use?
Old 03-25-2005, 12:53 AM
jemsite  is offline
Administrator
Images: 11
yes... if you use poor tools/technique you can strip the screw, especially when you almost run out of threads 'cause the body is not drilled that deep. i use 009s on double lockers... 010s or 011s on fixed bridge myself...glen
Old 03-25-2005, 01:00 AM
unique77  is offline
Well. . . Thank you very much.
fixed bridge, gauge strings, guage strings
Dumb question - adding 4th spring on edge block horstausmforst Tech: Setup, Repairs and Mods 17 09-10-2002 09:03 AM
Rack-mounted spring reverb? Like the Peavey ValVerb? bduersch Gear and Equipment 2 08-05-2002 07:53 PM
Trouble w/ Arm Holder Spring in Lo-Pro Edge - Help! elfstones Tech: Setup, Repairs and Mods 11 03-31-2002 03:25 PM
Parts for JEM7VWH - Trem cavity cover for JEM7VWH scarello JEM and Universe Guitars 5 03-14-2002 02:17 AM
Range - Range of the... mushroom JEM and Universe Guitars 9 05-22-2001 07:07 AM
