klick kluck edge problem 7vwh
04-25-2012, 12:24 AM
judoka777
Posts: 141 - iTrader: (
Ok jem 7v is my first experience with edge tremolo. i didnt have any troubles to set it up. The issue is that sometimes when i do big pull of or divebombs it makes some kclicking noice....kind of like something is hitting wood ...it also feels like something is moving...i meant i can feel that it has some physical movement besides noise.
P. S studs are locked ....i tightened inserts clockwise ..right ?
judoka777
Find all posts by judoka777
04-25-2012, 12:35 AM
steve
Posts: 616 - iTrader: (
Re: klick kluck edge problem 7vwh
I wonder if that might be the arm holder...
Could also be a string inserted off-center into one of the saddles (especially the non-wounds) - big bends can make the string slide across the saddle and 'ping' in the rounded channel.
But, definitely check for tightness of the arm holder - that's a 2-stage affair; the whole thing is locked from beneath by a 10mm nut, and the entire sub-assembly is threaded into the main bridge plate ahead of being locked by that nut.
Move the bar and watch/feel for movement in the holder.
(Do you keep your bar firm in its socket, or free-swinging?)
Cheers.
steve
Visit steve's homepage!
Find all posts by steve
04-25-2012, 12:37 AM
judoka777
steve
Cheers.
Sorry I didn't understand what you mean by this?
Keep it in socket ?? I might think wrong way but I thought that bar has only one position - free swinging ...I guess maybe I am missing something
judoka777
04-25-2012, 12:40 AM
steve
When you're playing, does the actual black trem bar stay where you put it when you let go, or does it fall down to point toward the floor?
Hope that makes sense =]
steve
04-25-2012, 12:55 AM
judoka777
steve
Yes make sense))) It fall down...The reason why I was confused in previouse post cuz I thought it cannot work other way . And that what I didn't really like . from what you saying I assume I can make it stay in some position ?
judoka777
04-25-2012, 03:24 AM
Sledgeman
Posts: 130 - iTrader: (
To make the arm firm, get new bushings like this
And get alot of them. They get worn down pretty fast.
Sledgeman
Find all posts by Sledgeman
04-25-2012, 04:42 AM
judoka777
I do use those bushings. Guitar is brand new and arm is swinging with those bushings ,,,,
judoka777
04-25-2012, 02:15 PM
judoka777
even with new bushings bar is still swinging around
judoka777
04-25-2012, 02:36 PM
leathermonkey7
Posts: 388 - iTrader: (
Reviews: 3
Pull of the rear term cavity cover, and look at the bottom of the arm holder. There is a small screw holding in a little arm retention spring. If this spring is not tight and in the correct place, it can cause the exact symptoms you describe.
leathermonkey7
Find all posts by leathermonkey7
04-25-2012, 02:39 PM
judoka777
leathermonkey7
I went through manual on ibanez rulez but still confused. Would you please tell me how can I make sure it is in correct place
judoka777
04-26-2012, 05:49 PM
ozzuk
Posts: 212 - iTrader: (
Reviews: 12
It could be the arm holder is loose or has a wobble,it may need the nut on the back tightening too and the screw that is directly below the arm on the backside tightening.
The only other reason is the bridge is catching on something but it sounds more of a mechanical problem, especially with the constantly loose arm it should feel quite tight and not move easily when new bushings are used.
I believe rich has a specific guide on loose arm holders.
http://www.ibanezrules.com/tech/setup/loose_holder.htm
check the nut and scre that attach it to the bridge if either of these are loose you will get movement and noises...
Good luck!
ozzuk
Find all posts by ozzuk
04-28-2012, 01:48 PM
judoka777
ozzuk
Good luck!
I went through that manual from ibby rulez. I am kind of located sound and it is coming from nut area. I tightened my nut pretty light to make sure I dodnt crack wood like many old rg's had.
judoka777
edge jem7vwh
Problem with 2003 7Vwh JEM, Possibly New Edge Pro Trem Fault
leonard deroma
06-18-2007
10:57 AM
JEM 7VWH wiring problem
prsguitar
Pickups & wiring
10:24 AM
7VWH Pickup Problem
Kremlin
Pickups & wiring
09:54 AM
problem with my jem 7vwh: help !
shredmaster
06-19-2002
08:40 AM
pitch problem - my 7vwh
swiggy
11:04 AM
10:07 AM
