ok so i have taken the trem out, but i dont understand the instructions on tightening the arm holder.
Only grab the END of the arm holder with the pliers because if you use them anywhere else on the holder you'll deform the holder and the bar will not fit in it anymore.
is the "end" the part on the bottom with the screw and spring in it, or is it the other end with the nut?
how do i get a good grip on that?
