lo pro edge
Once your strings are fully stretched it should stay in near perfect tune if it's properly set up. *(perfect is impossible ya know)
Here's a hint to string tuning. *I always do all of my strings at once, this way I can properly clean the fretboard and oil it. *Once you have your new strings on, you can tune it close to pitch, if you are using the same gauge string the trem should be very close to level again once you are close to pitch. *When you tune your guitar do every other string and then come back on the strings you didn't do ie: *E, D, B, E, G, A. *This seems to balance the trem easier when you're tuning, I usually alternate too: *E, D, B, E, G, A, E, D, B, A, G, E,
after usually only 2 or 3 runs through, it is in excellent tune with no funny occurences. * The floating trem takes a bit to get used to but once you figure it out it is the greatest thing in the world.
(You think tuning a Jem with is tough, try doing a UV with that big heavy low B)
Jeremy
