Old 10-10-2007, 01:18 AM
eatsleepplayguitar  is offline
Posts: 65  -  iTrader: (0)
My Jem 7V review
Everything is pretty damn good...
I was not happy with the factory settings. Although the intonation is by far the best ive ever had.
It came with 9's, Im going to stick some 10's on cause its to flimsy. Maybe even 11's. By just lowering the trem system, I was not able to get a action without fret buzz i desire.
What Do most people around here use on there jems?
Old 10-10-2007, 01:36 AM
JJEMMER777  is offline
Posts: 8,374  -  iTrader: (5)
Re: My Jem 7V review
You just need to tweek the truss
I only use 9's on all my jems. You can go to 10's but you'll have to tighten the spring claw or add a spring. 11's is WAY TOO MUCH!!
You might as well have a fixed bridge
What a surprise
Old 10-10-2007, 07:14 AM
rob777vdy  is offline
Posts: 2,575  -  iTrader: (3)
Images: 3
like jemmer says the truss rod needs tweaking.only do this yourself if you know what you are doing.(messing around with truss rod = untold damage to the neck)be carefull.i use 9s cant get away with 10s way to stiff.
Old 10-10-2007, 08:36 AM
screamndemon69  is offline
Posts: 5,676  -  iTrader: (12)
Congrats.
I use 9's too. I tried 10's for awhile but came back to 9's to have more bend in the strings. I do use 10's on all my fixed type bridges but 9's on all my tremmed guitars.
Old 10-10-2007, 08:53 AM
Hutch34  is offline
Posts: 153  -  iTrader: (0)
Yeah, I used 10's on mine for a while, but ended up switching back recently and I like it a lot better- but to each his own.
Old 10-10-2007, 10:17 AM
richard1973  is offline
Posts: 957  -  iTrader: (1)
Reviews: 10
always used 9's, never tried 10's i've just stuck to what i've always known. Same with string make I've pretty much only ever used D'addrio XL120's. Even though I'm sure I wouldnt be able to tell difference to other 9's make I just like sticking to them.
Old 10-10-2007, 10:57 AM
GTR-MAN  is offline
Posts: 1,056  -  iTrader: (0)
Images: 8
I use 9's, I too tried 10's (too tight) and even 8's (too thin, way too thin).
Old 10-10-2007, 11:07 AM
Jemplyr77  is offline
Posts: 162  -  iTrader: (1)
9's. Tried 10 but it was too...thick and stiff.
Old 10-10-2007, 12:31 PM
Sigar  is offline
Posts: 107  -  iTrader: (0)
It's just about personal taste, but as most here say, 9 is the way to go. I've never had any reason to change to heavier gauge. I think they suite these types of guitars best, while fixed bridge guitars are better with 10's.
Old 10-10-2007, 12:36 PM
Dee  is offline
Posts: 8,514  -  iTrader: (2)
9-12-16-24-32-44. For a 7-string, add a 59 for the low B.
Gauge: 9-42 Standard Set
E: .009" [PL] = 13.13 pounds
B: .011" [PL] = 11.01 pounds
G: .016" [PL] = 14.68 pounds
D: .024" [NW] = 15.77 pounds
A: .032" [NW] = 15.77 pounds
E: .042" [NW] = 14.77 pounds
Total Tension = 85.13 pounds
^^ Crap.
Gauge: 9-44 Custom Set
B: .012" [PL] = 13.11 pounds
E: .044" [NW] = 16.10 pounds
Total Tension = 88.56 pounds
^^ Proper.
Old 10-10-2007, 06:34 PM
Ki swordsman  is offline
Posts: 1,273  -  iTrader: (0)
Gauge: 9-49 suave & raucously good set
E: .009" PL == 13.13lb
B: .013" PL == 15.38lb
G: .017" PL == 16.57lb
D: .026" NW == 18.41lb
A: .036" NW == 19.54lb
E: .049" NW == 19.68lb
total == 102.71 pounds
^^ Coolest.
Old 10-10-2007, 06:52 PM
Dee  is offline
15.38 lbs on the B string? Ouch.
Old 10-10-2007, 07:01 PM
Inzane  is offline
Posts: 572  -  iTrader: (1)
^^ Crap.
Just out of curiosity Dee, is this (^^^^^^ above) what our RG20THs are equipped with stock? I'm still on the original strings on mine, so I hadn't researched what to try next yet. I was probably going to get new strings put on when I take it in for a proper setup.
Thanks.
Old 10-10-2007, 08:32 PM
Jemwielder  is offline
Posts: 999  -  iTrader: (1)
Reviews: 6
I use slinky top heavy bottoms on mine. I prefer heavier strings usually, at least 10s (which are skinny top heavy bottoms.) Any floating bridge I own gets the slinky top heavy bottoms that way the trem is still very responsive. I use 13s on the acoustic and on the Gretsch I use 12s. 12s seem like the way to go on any hollowbody electric. Just gets the whole guitar to resonate more.
Old 10-11-2007, 07:06 AM
it's slinky like butter! .. on a regular set the b always feels slinky and easy to bend to me. if it doesn't need extra playing ease why sacrifice tone?
fixed bridge, fixed bridge guitar, fixed bridge guitars, fret buzz, truss rod
Greetings, from this new JEM owner! kingtj JEM and Universe Guitars 7 08-11-2004 01:45 PM
Tremolo on my Jem 77FP (i'm a new member) Nirgal JEM and Universe Guitars 2 05-06-2004 05:28 PM
Jem 7DBK or JS1000? stratman219 JEM and Universe Guitars 8 10-20-2002 03:25 PM
Nice story to tell - How I've found a JEM 10 jember JEM and Universe Guitars 9 03-20-2002 06:22 PM
Cheapy new JEM switches - New vs Old JEM pickup selectors rikkbeatty JEM and Universe Guitars 13 09-04-2001 01:51 PM
