My JEM's G string sounds funny
Page 2 of 2
04-04-2008, 02:18 PM
Devon8822
Posts: 389 - iTrader: (
Re: My JEM's G string sounds funny
Its unwound
Devon8822
Find all posts by Devon8822
04-04-2008, 04:12 PM
resha
Posts: 149 - iTrader: (
Check the nut, if the guitar is quite old (or if it's just being used a lot) it can be changed preventing the string to vibrate well (its center moved and the string is not in its original position anymore).
resha
Visit resha's homepage!
Find all posts by resha
04-05-2008, 01:10 PM
giannifive
Posts: 484 - iTrader: (
Devon8822, I had the same problem as you and it turned out to be the angle of the nut slot for the G string. The string wasn't making contact at the edge of the nut. Try Rich's test to see if this is the problem:
Take a heavy pick or a coin or something and press the string hard against the nut to seat it on it's edge, then pluck a note and see if it's changed.
giannifive
Find all posts by giannifive
04-06-2008, 01:03 AM
albee1952
Posts: 784 - iTrader: (
Also, check
nut height
like this: fret the string at the 3rd fret and look at the clearance at the first fret. If the string is touching the first fret, the nut needs a shim. There should be enough clearance to slip in a business card.
albee1952
Find all posts by albee1952
Page 2 of 2
nut height
pickup combo
wound strings
where to buy guitar string sin southampton
what distortion pedal can take guitars string 10-60
how do you get your amp to the brown sounds
use a .016 for the 2nd string?
jpx 7 string?
Leaving Ibanez guitars - No more jems for me
jem7pbk
12-11-2010
08:16 PM
LO TRS STRING SADDLE!!!!!!!!
zzzec
05:54 PM
Major Help! String Clamp Won't Budge!
Rekuss
Tech: Setup, Repairs and Mods
07:57 PM
MyHELP lack of good string muting is KILLLING ME!! - Fret ha
Triangle
Guitar Lessons & Music Theory
08:57 AM
7th string help
JN777
11:22 AM
07:16 PM
