Old 04-02-2008, 07:56 PM
Devon8822  is offline
Posts: 389  -  iTrader: (3)
My JEM's G string sounds funny
I have a problem with my JEM and I am wondering if anybody is familiar with the problem... I have no idea what is causing it or how to fix it and its driving me nuts. The best description I can give you is that the G strings tone is different from the other strings... including the other non-wound strings. It sound sorta hollow... maybe slightly less treble... Hollow is the best word to describe it though... like when you knock on a hollow tree. help?
Old 04-02-2008, 08:07 PM
The Euphor  is offline
Posts: 2,948  -  iTrader: (4)
Re: My JEM's G string sounds funny
The string only has to anchor points. Both ends are good places to start looking for anything "wrong". Might be a saddle with a loose screw. You might have attached the string backwards. This will result in a reverse sound.
Old 04-02-2008, 08:59 PM
Rich  is offline
Take a heavy pick or a coin or something and press the string hard against the nut to seat it on it's edge, then pluck a note and see if it's changed.
Old 04-02-2008, 09:03 PM
tt0511  is offline
Posts: 352  -  iTrader: (7)
ROFLMAO!
String either not seated in the nut, wound portion of string at the end is up in the locking part of the saddle, or a cracked saddle/loose saddle would be my guesses. Can't be a whole lot of things.
Old 04-02-2008, 10:17 PM
Rachmaninoff  is offline
Posts: 567  -  iTrader: (0)
Images: 5
Reviews: 11
ROFLMAO
Old 04-02-2008, 11:43 PM
albee1952  is offline
Posts: 784  -  iTrader: (2)
Nice!! Maybe its just a defective string.
Old 04-02-2008, 11:44 PM
Darin  is offline
Posts: 2,459  -  iTrader: (2)
Old 04-03-2008, 09:25 AM
GuitarAkuma  is offline
Posts: 210  -  iTrader: (0)
It's true! When I want to play those clever reversed guitar parts that Vai/Satch do I reverse all my strings and then its dead easy to play
Old 04-03-2008, 09:51 AM
Ibateur  is offline
Posts: 2,947  -  iTrader: (3)
poor guy...
GilkyBear  is offline
Posts: 4,110  -  iTrader: (16)
Hendrix being a lefty, all the strings were on backwards as they only had right handed guitar strings back then. This is how he got that tone on the solo to Purple Haze.
Old 04-03-2008, 09:53 AM
Vim Fuego  is offline
Posts: 908  -  iTrader: (2)
Images: 6
But guys, I've seen a lot of people put the ball ends of the strings at the tuners, they can't all be playing reverse guitar parts! Maybe if you then play the guitar upside down it cancels out? Perhaps these guys are all from the southern hemisphere and I never noticed!
If you can't find anything lose, could the intonation be badly out on that particular string causing overtones? Or, could it be the single coil raised too high causing the string's vibration to be uneven in the strong magnetic field.
Jim
Old 04-03-2008, 05:44 PM
I have always put my strings on backwards with the ball end at the headstock...
keep in mind its only the g string. I have checked the nut and the bridge and everything is normal. It does this even if I change the strings... i cannot figure it out. Any more ideas?
Old 04-03-2008, 06:02 PM
wilch  is offline
Posts: 1,783  -  iTrader: (0)
Images: 1
Checked intonation?
Old 04-03-2008, 06:40 PM
JayRobIBZ  is offline
Posts: 530  -  iTrader: (1)
Reviews: 3
my first thought would be pole pieces at the wrong height. but if it does it on every pickup combo then it is more likely to be because one was too close, as stated before. if nothing else try getting a wound g string.
Old 04-04-2008, 01:19 AM
fyrie  is offline
Posts: 397  -  iTrader: (0)
Some people claim that a wound G string is a flaw in itself
http://carvinbbs.com/viewtopic.php?t=5949
nut height, pickup combo, wound strings
Leaving Ibanez guitars - No more jems for me jem7pbk JEM and Universe Guitars 141 12-11-2010 08:16 PM
LO TRS STRING SADDLE!!!!!!!! zzzec Other Ibanez Guitars (including Premiums) 2 12-06-2007 05:54 PM
Major Help! String Clamp Won't Budge! Rekuss Tech: Setup, Repairs and Mods 9 02-24-2007 07:57 PM
MyHELP lack of good string muting is KILLLING ME!! - Fret ha Triangle Guitar Lessons & Music Theory 3 05-31-2005 08:57 AM
7th string help JN777 JEM and Universe Guitars 8 02-07-2004 11:22 AM
