Orig Edge backwards travel
10-27-2008, 04:50 PM
Devon8822
Posts: 389 - iTrader: (
My edge on my 1990 Jem, when you take the trem back far enough the strings end up hitting the intonation screws. I am just wondering if this is what happens on all jems, when you move the trem back far enough?
Devon8822
Find all posts by Devon8822
10-27-2008, 05:03 PM
markg5150
Posts: 2,361 - iTrader: (
Re: Orig Edge backwards travel
Is the neck shimmed or the action quite high? If the trem doesn't bottom out in the cavity the strings will touch the 24th fret
markg5150
Find all posts by markg5150
10-27-2008, 05:06 PM
eruji
Posts: 81 - iTrader: (
I dont own a jem but would imagine it should be setup just like any other edge system. It sounds like a combination of your bridge floating (at its neutral position) at too much of back angle, meaning the side closest to the heel of the guitar. Along with a high bridge i suppose its possible to pull up so much that it bottoms out on the intonation screws. Take a look at some of the pictures of a properly setup edge angle to verify this first.
eruji
Find all posts by eruji
10-27-2008, 05:42 PM
Devon8822
I setup all my guitars, I knwo what I am doing in that manner. It is setup properly the bridge is level where it should be.
Devon8822
10-27-2008, 05:55 PM
eruji
how may semi-tones up are you getting? meaning if you fret a G at the third fret on the high e.. then pull up on the trem arm.. what note do you end up at before it bottoms out? also some pics of the bridge might help. I believe you should get somewhere between 2-4 semi-tones with a typical setup. And are you sure you not bottoming out on the fretboard... (ibanez rules says perfect fourth is attainable... 5 semitones)
eruji
10-27-2008, 06:51 PM
robare99
Posts: 310 - iTrader: (
sounds like the trem might be a bit high. On my main RG550, with the open G string, I can pull back and raise the note 7 semitones. It bottoms out on the cavity, before hitting the intonation screws.
robare99
Find all posts by robare99
10-27-2008, 06:54 PM
Devon8822
My travel is fine I am not worried about that, I was just wondering if anyone else bottoms out in this way too? Instead of hitting the back of the recess first.
Devon8822
will edge zero pro fit edge 3 route?
how is the edge zero?
is my edge trem bar in all the way
Should i change my orig. PAF Pro to a Fred?
LTE
12:12 AM
Air travel help?
jay ratkowski
Off-topic / Miscellaneous
12:46 AM
backwards?
JimmyW
Pickups & wiring
02:58 PM
Re-Strung Backwards - ??????
Dead Roman
Gear and Equipment
10:49 AM
04:30 PM
